Re: need hole location for remote mirror control on 70 bee
[Re: ogopogo]
#2638782
03/30/19 10:59 AM
03/30/19 10:59 AM
Posts: 798 WA
pro451bee
WA
Does the remote mirror bolt on like the other one did? I like to change over mine to the remote style too.
[Re: ogopogo]
#2639244
03/31/19 05:38 PM
03/31/19 05:38 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
It is directly about the tiny little plastic plug, half way between top/bottom of the upper door interior section. There's a thin, square "slip over" clip that holds in place from the inside
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: ogopogo]
#2639948
04/01/19 10:41 PM
04/01/19 10:41 PM
Posts: 18,160 Mass
DAYCLONA
Mass
it is a couple inches in front of the little plastic plug but Im looking for an exact dimension if someone has a 70 coronet they could measure for me..... D, Could you use the interior panel to locate it?, the centerline of the remote toggle seems to follow the vertical trim line of the installed door panel, and it appears somewhat centered between the 2 horizontal raised lines of the top door panel.... and IIRC there's usually a small dimple on that upper portion of the door that was a drilling/knock out location for the line worker ...yes? Mike
[Re: ogopogo]
#2640126
04/02/19 10:45 AM
04/02/19 10:45 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Looks as though it is also in line with the upper wing window mount. That should be the same from model to model, no?
I have mechanical Aptitude. I can screw up anything.
[Re: Morty426]
#2640491
04/03/19 02:23 AM
04/03/19 02:23 AM
Posts: 1,797 BC Canada
ogopogo
BC Canada
