Re: Another 68 Hemi RR Question
[Re: viperakron]
#263713
03/23/09 06:55 PM
03/23/09 06:55 PM
Posts: 25,995 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Look on the part of the pan rail that extends under the starter, there might be an engine number stamped there.
The top pad on a November '67 built car would have a late '67 assembly date.
[Re: viperakron]
#263715
03/24/09 05:52 PM
03/24/09 05:52 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
It might have a '66 cast block due to the factory running off a batch and then slowly using them.
Some of the last year '71 Hemis have earlier cast blocks.
I want my fair share
[Re: viperakron]
#263717
03/24/09 08:06 PM
03/24/09 08:06 PM
John_Kunkel
Rio Linda, CA
Early '68 might or might not have a VIN stamped in the block/trans. Serial number will be on the pan rail under the starter.
[Re: ScottSmith_Harms]
#263721
03/24/09 10:02 PM
03/24/09 10:02 PM
Posts: 196 West Central Indiana
Mr.Runum
IIRC all blocks would be before '67 in most '68 as ther were no Hemi's cast in '67
69 RoadRunner 383 4spd coupe, 06 Hemi Daytona Charger, 08 6.7 RAM QC short bed 3/4 4X4
[Re: viperakron]
#263724
03/25/09 11:47 AM
03/25/09 11:47 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
States cars built before Jan 68 didn't have identification other than engine pad assembly date.
This is simply not a correct statement. Keep in mind the owner (dealer?) is trying to make a sale.
If correct numbers are important to you I would not reccomend buying that car without having it looked at by someone knowledgable first (Galen Govier, Dave Wise, Myself, etc. pick one).
[Re: hemirdrnnr]
#263729
03/25/09 02:15 PM
03/25/09 02:15 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Request by whom? The Federal government mandated that beinning in January 1968 all vehicles were to have the VIN sequence number stamped into the engine and transmission. However, Chrysler took it upon themselves to add them in the beggining of the 1968 production model year (mandated or not). As I said, I've seen several VERY early original cars that did have the VIN Sequence stampings, it makes sense to believe they all did or at least were supposed to have. As far as reports of some finding no VIN sequence stampings on thier blocks, I wouldn't doubt there were some built that way, but have never seen a documented example that lacked it(such as a survivor or a complete original unmolested car that's never been appart etc.). Do some exist? Possibly, I'm just waiting to see someone step up with a good verifiable example before I commit to it as an absalute. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: viperakron]
#263730
03/25/09 02:21 PM
03/25/09 02:21 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Then where would you look for the serial# stamp?
It's not a "Serial" #, it's the last portion of the cars VIN#. on a 1966 cast dated block it would normally be found on the rear bell housing mating surface of the upper block.
