Big job removing bed from frame, '79 W150? #2636412
03/24/19 01:04 PM
03/24/19 01:04 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I would like to remove the bed from frame on my '79 W150 short bed so that I can really get to the frame for cleaning and painting. I've already removed the under-bed plastic gas tank because it was cracked and leaking, and I just run off the behind the seat tank, so that's out of way. I'm wondering how big of a job this will be. Four mounts? No spare mounted under there. Can two reasonably strong people lift the bed off frame and set it aside? I would imagine it's pretty heavy.
Thanks,
Larry
Facts are stubborn things.
Re: Big job removing bed from frame, '79 W150? [Re: larrymopar360] #2636445
03/24/19 02:04 PM
03/24/19 02:04 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Don't forget the taillights and wiring. wink Start soaking the nuts with penetrant a day or two ahead of time if you haven't already. I would try to round up at least 3 buddies to help lift it. Been a while since I did the '85 I had but seems like there was a grounding strap on the D. front side of the bed? work
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Big job removing bed from frame, '79 W150? [Re: larrymopar360] #2636451
03/24/19 02:08 PM
03/24/19 02:08 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Yep, if you're using people power to remove it, you'll need 4 strong backs. They're pretty heavy.
Re: Big job removing bed from frame, '79 W150? [Re: Fat_Mike] #2636476
03/24/19 03:07 PM
03/24/19 03:07 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
If you take your time and work carefully, it can be done by one person with no special tools, I R&R'd an 8ft bed on a '76 Club Cab I used to own.
BUT, that was back when I was in my 20's too.
If you don't have a hoist or lift you can use, bribe your friends with beer. A 6 or 12 pack is w-a-y cheaper than a trip to the ER.
It's really not the difficult. I would suggest removing the wheels and maybe the bumper too so the bed doesn't have to be lifted as high.
John
Re: Big job removing bed from frame, '79 W150? [Re: SattyNoCar] #2636502
03/24/19 04:08 PM
03/24/19 04:08 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Ok, thanks for tips. I did plan on hosing the bolts with PB Blaster.
I figured it's pretty heavy. I don't have a hoist. Pretty good set of hand tools, and that's about it. Taillights and tag light, remove mounts (Four?) My brother plus two friends (beer bribe grin). I plan to remove bumper anyway because I want to treat and paint because of rust scale. I already have spent hours on the frame, cleaning and painting what I can reach with POR 15 (at least one Migraine from the smell despite my mask), but now realize there's really only one right way.
Re: Big job removing bed from frame, '79 W150? [Re: larrymopar360] #2636533
03/24/19 04:56 PM
03/24/19 04:56 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
short bed should have 6 bolts--long bed 8 bolts----if you have an engine cherry picker you can do it by yourself--bed has to have a tailgate----run the cherry picker in the back---lower the boom into the bed---cut a 2x2 piece of steel to fit under the bed rail----the end of the cherry picker comes up against the steel bar (may want to drill a hole and set a bolt so it doesnt slip-----jack up the cherry picker---first the tailgate comes up against the boom---then the nose of the cherry picker picks up the bed.....roll away....might see it on Utube....----oh yeah---2 guys can do it---i am 70 years old and my son and i can lift them off at the pickapart....
Re: Big job removing bed from frame, '79 W150? [Re: savoy64] #2636617
03/24/19 08:14 PM
03/24/19 08:14 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
i made a bed lifting tool out of a 4x4. i measured the distance on the inside of bed and subtracted , i think,3/8 inch from each side. i then put 2x2's( actually they measure 1 3/8x1 3/8) on top of each end so they fit under bed rail. then i took 2 eye bolts and measured in 12 inches from each end and drilled hole in 4x4. put chain in eyelets and use cherry picker to lift it off by myself. it will take a few tries to get bed to lift up evenly. but it works for me.
Re: Big job removing bed from frame, '79 W150? [Re: rbkt65] #2636637
03/24/19 08:59 PM
03/24/19 08:59 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
https://www.summitracing.com/parts/wmp-tbl0013
Or make one... pretty simple. Then its a one man job with a cherry picker
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Big job removing bed from frame, '79 W150? [Re: W.I.N. Racing] #2636660
03/24/19 09:38 PM
03/24/19 09:38 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Two guys can do it. My 16 year old son and I did it so I'm pretty sure you can too. As I recall 2 of the bolts take a bit of time to undo, the rest of it is easy.
Sheldon
Re: Big job removing bed from frame, '79 W150? [Re: RUNCHARGER] #2636781
03/25/19 07:37 AM
03/25/19 07:37 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
Two guys can do it. Taking the bumper off helps.Grap on each side above the wheels and walk it off.
1981 Dodge D150 360 auto
Re: Big job removing bed from frame, '79 W150? [Re: basketcase] #2636788
03/25/19 08:03 AM
03/25/19 08:03 AM
south louisiana
lowell66dart Offline
south louisiana
Take the tires off too. That way it just can slide back without lifting it much.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: Big job removing bed from frame, '79 W150? [Re: W.I.N. Racing] #2636882
03/25/19 10:19 AM
03/25/19 10:19 AM
RWG75
RWG75
kinda pricey. I achieved the same thing by using a few light weight chains and bolts. Run one side to side and bolt to the holes in the stake pocket. One in the front, one in the back, another piece connecting them in the center. Exact same H shape done with chain I had hanging around. Grab it with the engine hoist. Maybe toss some random scrap in the bed to level it out depending on pick point and bed length.
Re: Big job removing bed from frame, '79 W150? [Re: lowell66dart] #2636993
03/25/19 02:46 PM
03/25/19 02:46 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
ive done several, usually 2 guys.
My word of advice is put a blanket over the front edge and corners so that you have a small buffer between cab and bed.
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: Big job removing bed from frame, '79 W150? [Re: ViperDave] #2637059
03/25/19 06:12 PM
03/25/19 06:12 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
With a short bed, an engine hoist with straps would be all that is needed. I removed the long bed of my 70 D100 this way too, but it would be far easier with a short bed.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Big job removing bed from frame, '79 W150? [Re: larrymopar360] #2637077
03/25/19 06:40 PM
03/25/19 06:40 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
What soopernaut said. Should be easier not lifted.
Re: Big job removing bed from frame, '79 W150? [Re: redraptor] #2637380
03/26/19 02:28 PM
03/26/19 02:28 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I guess I could rent an engine hoist.I do like the idea of doing it that way. I wouldn't mind buying equipment for future use, but I have no storage room. It's all taken up now with cars, parts, and tools. Even a spare bedroom is filled with the cleaner of the parts.
I was under the truck yesterday after work looking more closely, and it really does look pretty easy to unbolt and very little attached otherwise.
Thanks all and I appreciate the pics too.
Re: Big job removing bed from frame, '79 W150? [Re: larrymopar360] #2637388
03/26/19 02:51 PM
03/26/19 02:51 PM
RWG75
RWG75
Or maybe toss a chain over a big solid branch and use a come along. Dunno what kinda control you'd have over letting it back down. Pull the bolts out, disco the fuel fill, lights, whatever, pick up one side to get feel for the weight, grab a neighbor for 5 minutes.
Re: Big job removing bed from frame, '79 W150? [Re: ] #2637491
03/26/19 08:38 PM
03/26/19 08:38 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
If I do rent a hoist I will strap toward cab more so I don't tilt up toward the front and hit cab. I will cover cab as suggested. I'll have my brother with me.
Re: Big job removing bed from frame, '79 W150? [Re: larrymopar360] #2637703
03/27/19 12:53 PM
03/27/19 12:53 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Whatever you do, do not just string a chain from say the left rear corner to the right front corner and lift it that way! We did that on my sons 84 Short Bed and it flexed so much the quarters had "waves" in them. Wish I had a pic of the look on his face when he saw it... Fortunately, when we set it back on the frame it all settled out (much to his relief LOL). Seemed like good idea at the time, Not so much.
Re: Big job removing bed from frame, '79 W150? [Re: larrymopar360] #2637712
03/27/19 01:14 PM
03/27/19 01:14 PM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
I built a Swing set type frame out of Maple Trees about 8 inches around and used a chain hoist to lift mine off, When I was done cut the Maple trees up for fire wood...
