Re: 5.7 intake on 6.1?
[Re: DAYCLONA]
#2636017
03/23/19 04:58 PM
03/23/19 04:58 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I have an eagle 5.7 intake on my 6.1, you have to mod the intake some on the bottom as it hits the block in front. The ports are different on the earlier 5.7 intakes.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2636485
03/24/19 03:24 PM
03/24/19 03:24 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks for the current input guys, but being a newbie to the Gen 3 HEMI, Eagle this, Eagle that? are we talking aftermarket components?, I'm just curious if the Edelbrock 5.7 dual quad carb manifold is 5.7 only?, or can it fit STOCK 6.1 or 6.4 Gen3 HEMIs without modding/swapping heads...no one (mfg's included) seems to have any input as to whether the Edelbrock bolts ups to anything other than a 5.7....I can deal with port shape mismatch, but I'm more concerned with the actual fit, I don't have access to a 6.1 or 6.4 to test this, I don't even know if 6.1 and 6.4 Gen#'s are interchangeable among themselves?
TIA Mike
[Re: RTSE4ME]
#2636558
03/24/19 06:09 PM
03/24/19 06:09 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike- Eagle is the 2009 & later 5.7. Different heads and VVT are the main differences vs the early 5.7s The bolt patterns are all the same but the early 5.7L heads (03-08) are there own entity and have a narrow but tall port and the eagle,6.1L,6.2L,6.4L heads all have the same port window and are wide and short. Also if you plan on using the MSD ignition controller they only work with the early reluctor wheels unless MSD has upgraded. OK better understood Thank You....the plan is for a "dumbed down" HEMI (flame suit on!) Gen 3 running dual quads and a distributor/single plug per cylinder, no computer/MSD/VVT/WT etc, etc mated to a 6 spd T56, I'm probably stuck going with an early 5.7 engine but I'm weighing my options going with 6.1-6.4 and trying to learn whats doable before I invest in an engine Thanks Mike
[Re: Fishstix]
#2637401
03/26/19 03:32 PM
03/26/19 03:32 PM
Posts: 2,256 IL
furious70
IL
I'm guessing he wants the look of the dual carb intake on his 'old school' Gen III
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Fishstix]
#2637490
03/26/19 08:36 PM
03/26/19 08:36 PM
Posts: 112 Michigan
ghinmi
You will be stuck with a 6.1 or 2008-older 5.7 block if you're going to use the distributor conversion.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: ghinmi]
#2637518
03/26/19 09:46 PM
03/26/19 09:46 PM
Posts: 18,157 Mass
DAYCLONA
Mass
You will be stuck with a 6.1 or 2008-older 5.7 block if you're going to use the distributor conversion. I'm fine with that, I just wanted to know if the 5.7 intake was compatible with 6.1/6.4 engines, as for the 6.1 am I limited to 2006 to 2008 production?, or up to 2011 engines regarding the distributor set up? Thank you for the input Mike
