Big job removing bed from frame, '79 W150?
#2636412
03/24/19 01:04 PM
03/24/19 01:04 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I would like to remove the bed from frame on my '79 W150 short bed so that I can really get to the frame for cleaning and painting. I've already removed the under-bed plastic gas tank because it was cracked and leaking, and I just run off the behind the seat tank, so that's out of way. I'm wondering how big of a job this will be. Four mounts? No spare mounted under there. Can two reasonably strong people lift the bed off frame and set it aside? I would imagine it's pretty heavy.
Thanks,
Larry
Facts are stubborn things.
Re: Big job removing bed from frame, '79 W150?
[Re: larrymopar360]
#2636445
03/24/19 02:04 PM
03/24/19 02:04 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Don't forget the taillights and wiring. Start soaking the nuts with penetrant a day or two ahead of time if you haven't already. I would try to round up at least 3 buddies to help lift it. Been a while since I did the '85 I had but seems like there was a grounding strap on the D. front side of the bed? Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: Fat_Mike]
#2636476
03/24/19 03:07 PM
03/24/19 03:07 PM
Posts: 16,840 Between Houston & Galveston TX
SattyNoCar
If you take your time and work carefully, it can be done by one person with no special tools, I R&R'd an 8ft bed on a '76 Club Cab I used to own.
BUT, that was back when I was in my 20's too.
If you don't have a hoist or lift you can use, bribe your friends with beer. A 6 or 12 pack is w-a-y cheaper than a trip to the ER.
It's really not the difficult. I would suggest removing the wheels and maybe the bumper too so the bed doesn't have to be lifted as high.
John
[Re: SattyNoCar]
#2636502
03/24/19 04:08 PM
03/24/19 04:08 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Ok, thanks for tips. I did plan on hosing the bolts with PB Blaster. I figured it's pretty heavy. I don't have a hoist. Pretty good set of hand tools, and that's about it. Taillights and tag light, remove mounts (Four?) My brother plus two friends (beer bribe ). I plan to remove bumper anyway because I want to treat and paint because of rust scale. I already have spent hours on the frame, cleaning and painting what I can reach with POR 15 (at least one Migraine from the smell despite my mask), but now realize there's really only one right way.
[Re: larrymopar360]
#2636533
03/24/19 04:56 PM
03/24/19 04:56 PM
Posts: 2,042 colorado
savoy64
colorado
short bed should have 6 bolts--long bed 8 bolts----if you have an engine cherry picker you can do it by yourself--bed has to have a tailgate----run the cherry picker in the back---lower the boom into the bed---cut a 2x2 piece of steel to fit under the bed rail----the end of the cherry picker comes up against the steel bar (may want to drill a hole and set a bolt so it doesnt slip-----jack up the cherry picker---first the tailgate comes up against the boom---then the nose of the cherry picker picks up the bed.....roll away....might see it on Utube....----oh yeah---2 guys can do it---i am 70 years old and my son and i can lift them off at the pickapart....
[Re: rbkt65]
#2636637
03/24/19 08:59 PM
03/24/19 08:59 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
https://www.summitracing.com/parts/wmp-tbl0013Or make one... pretty simple. Then its a one man job with a cherry picker
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2636660
03/24/19 09:38 PM
03/24/19 09:38 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
Two guys can do it. My 16 year old son and I did it so I'm pretty sure you can too. As I recall 2 of the bolts take a bit of time to undo, the rest of it is easy.
Sheldon
[Re: RUNCHARGER]
#2636781
03/25/19 07:37 AM
03/25/19 07:37 AM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
Two guys can do it. Taking the bumper off helps.Grap on each side above the wheels and walk it off.
1981 Dodge D150 360 auto
[Re: basketcase]
#2636788
03/25/19 08:03 AM
03/25/19 08:03 AM
Posts: 885 south louisiana
lowell66dart
south louisiana
Take the tires off too. That way it just can slide back without lifting it much.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: W.I.N. Racing]
#2636882
03/25/19 10:19 AM
03/25/19 10:19 AM
RWG75
RWG75
kinda pricey. I achieved the same thing by using a few light weight chains and bolts. Run one side to side and bolt to the holes in the stake pocket. One in the front, one in the back, another piece connecting them in the center. Exact same H shape done with chain I had hanging around. Grab it with the engine hoist. Maybe toss some random scrap in the bed to level it out depending on pick point and bed length.
[Re: lowell66dart]
#2636993
03/25/19 02:46 PM
03/25/19 02:46 PM
Posts: 4,696 enfield, CT
ViperDave
enfield, CT
ive done several, usually 2 guys.
My word of advice is put a blanket over the front edge and corners so that you have a small buffer between cab and bed.
67 Dart GT Vert 273/904 72 Town & Country 440/727 90 D350 reg cab dually cummins 15 Scat Pack Challenger
[Re: ViperDave]
#2637059
03/25/19 06:12 PM
03/25/19 06:12 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
With a short bed, an engine hoist with straps would be all that is needed. I removed the long bed of my 70 D100 this way too, but it would be far easier with a short bed.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: redraptor]
#2637380
03/26/19 02:28 PM
03/26/19 02:28 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I guess I could rent an engine hoist.I do like the idea of doing it that way. I wouldn't mind buying equipment for future use, but I have no storage room. It's all taken up now with cars, parts, and tools. Even a spare bedroom is filled with the cleaner of the parts.
I was under the truck yesterday after work looking more closely, and it really does look pretty easy to unbolt and very little attached otherwise.
Thanks all and I appreciate the pics too.
[Re: larrymopar360]
#2637388
03/26/19 02:51 PM
03/26/19 02:51 PM
RWG75
RWG75
Or maybe toss a chain over a big solid branch and use a come along. Dunno what kinda control you'd have over letting it back down. Pull the bolts out, disco the fuel fill, lights, whatever, pick up one side to get feel for the weight, grab a neighbor for 5 minutes.
[Re: ]
#2637491
03/26/19 08:38 PM
03/26/19 08:38 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
If I do rent a hoist I will strap toward cab more so I don't tilt up toward the front and hit cab. I will cover cab as suggested. I'll have my brother with me.
