cab differences #2636085
03/23/19 07:17 PM
03/23/19 07:17 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
what are the differences between cabs from 72-80 and 81 up? i know the body lines on the fenders are different,i think. have a couple good cabs for 81 up but 72-80 trucks are expensive if you find a decent one. thanks in advance
Re: cab differences [Re: rbkt65] #2636107
03/23/19 08:05 PM
03/23/19 08:05 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I think it's in the roof line for the most part (except for club cabs, I think they're the same)
Re: cab differences [Re: WO23Coronet] #2636153
03/23/19 09:36 PM
03/23/19 09:36 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
the area where the bulkhead connector goes thru the firewall is a different shape. Nothing that can't be dealt with.
and it can depend on whether you're working on a 2WD or 4WD...some 2WD trans tunnels aren't as high as a 4WD.
1981 Dodge D150 360 auto
Re: cab differences [Re: basketcase] #2636291
03/24/19 10:05 AM
03/24/19 10:05 AM
5thAve Offline
5thAve  Offline
The roof line is rounded on on the older ones and went more squared off for 1981. Crew cab and I think extended cab kept the old roof.
Re: cab differences [Re: 5thAve] #2636301
03/24/19 10:25 AM
03/24/19 10:25 AM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
thanks.
Re: cab differences [Re: rbkt65] #2636356
03/24/19 11:40 AM
03/24/19 11:40 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Heater box opening.. bunch of little things
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: cab differences [Re: rbkt65] #2637080
03/25/19 06:47 PM
03/25/19 06:47 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
What W.I.N. said. I think even the cab mount locations are slightly different.
