5.7 intake on 6.1? #2635705
03/22/19 08:55 PM
03/22/19 08:55 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Hey guys, wanting to know if the 5.7 intake can be bolted to the 6.1-6.4 engines?....
TIA
Mike
Re: 5.7 intake on 6.1? [Re: DAYCLONA] #2635756
03/23/19 12:32 AM
03/23/19 12:32 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I think it is more dependent on the cylinder head era.The early 5.7/6.1 I believe are interchangeable or at least are a close fit,6.1 intakes have been installed on the early 5.7 as a mod. The later 5.7 and 6.4 may swap,the ports are a bit different shape than the pre-eagle heads.
Re: 5.7 intake on 6.1? [Re: DAYCLONA] #2636017
03/23/19 04:58 PM
03/23/19 04:58 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I have an eagle 5.7 intake on my 6.1, you have to mod the intake some on the bottom as it hits the block in front. The ports are different on the earlier 5.7 intakes.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 5.7 intake on 6.1? [Re: Silver70] #2636485
03/24/19 03:24 PM
03/24/19 03:24 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
Thanks for the current input guys, but being a newbie to the Gen 3 HEMI, Eagle this, Eagle that? are we talking aftermarket components?, I'm just curious if the Edelbrock 5.7 dual quad carb manifold is 5.7 only?, or can it fit STOCK 6.1 or 6.4 Gen3 HEMIs without modding/swapping heads...no one (mfg's included) seems to have any input as to whether the Edelbrock bolts ups to anything other than a 5.7....I can deal with port shape mismatch, but I'm more concerned with the actual fit, I don't have access to a 6.1 or 6.4 to test this, I don't even know if 6.1 and 6.4 Gen#'s are interchangeable among themselves?
TIA
Mike
Re: 5.7 intake on 6.1? [Re: DAYCLONA] #2636529
03/24/19 04:46 PM
03/24/19 04:46 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Mike- Eagle is the 2009 & later 5.7. Different heads and VVT are the main differences vs the early 5.7s
The bolt patterns are all the same but the early 5.7L heads (03-08) are there own entity and have a narrow but tall port and the eagle,6.1L,6.2L,6.4L heads all have the same port window and are wide and short.
Also if you plan on using the MSD ignition controller they only work with the early reluctor wheels unless MSD has upgraded.
Re: 5.7 intake on 6.1? [Re: RTSE4ME] #2636558
03/24/19 06:09 PM
03/24/19 06:09 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
OK better understood Thank You....the plan is for a "dumbed down" HEMI (flame suit on!) Gen 3 running dual quads and a distributor/single plug per cylinder, no computer/MSD/VVT/WT etc, etc mated to a 6 spd T56, I'm probably stuck going with an early 5.7 engine but I'm weighing my options going with 6.1-6.4 and trying to learn whats doable before I invest in an engine
Mike
Re: 5.7 intake on 6.1? [Re: DAYCLONA] #2636779
03/25/19 07:30 AM
03/25/19 07:30 AM
Charleston SC
Fishstix Offline
Fishstix  Offline
Charleston SC
This is the first time I have read about this swap. Plenty about a 6.1 intake on a 5.7 .
What is the advantage?
Re: 5.7 intake on 6.1? [Re: Fishstix] #2637401
03/26/19 03:32 PM
03/26/19 03:32 PM
IL
furious70 Offline
furious70  Offline
IL
I'm guessing he wants the look of the dual carb intake on his 'old school' Gen III
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 5.7 intake on 6.1? [Re: furious70] #2637410
03/26/19 04:02 PM
03/26/19 04:02 PM
Charleston SC
Fishstix Offline
Fishstix  Offline
Charleston SC
Ahhhh, missed the dual quad reference.
Re: 5.7 intake on 6.1? [Re: Fishstix] #2637490
03/26/19 08:36 PM
03/26/19 08:36 PM
ghinmi Offline
ghinmi  Offline
You will be stuck with a 6.1 or 2008-older 5.7 block if you're going to use the distributor conversion.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: 5.7 intake on 6.1? [Re: ghinmi] #2637518
03/26/19 09:46 PM
03/26/19 09:46 PM
Mass
DAYCLONA Offline OP
DAYCLONA  Offline OP
Mass
I'm fine with that, I just wanted to know if the 5.7 intake was compatible with 6.1/6.4 engines, as for the 6.1 am I limited to 2006 to 2008 production?, or up to 2011 engines regarding the distributor set up? Thank you for the input
Mike
Re: 5.7 intake on 6.1? [Re: DAYCLONA] #2637520
03/26/19 10:00 PM
03/26/19 10:00 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Any 6.1(iron or aluminum) can use distributor set up since no VVT.
Only disadvantage of 6.1 is cost compared to early 5.7.
