Page 3 of 3 1 2 3
Re: 4 Speed -- What would you do / Choose? [Re: rabid scott] #263554
03/25/09 06:36 PM
03/25/09 06:36 PM
hemisurfer Offline
hemisurfer  Offline
23 spline 1.248 " ...plenty big
18 spline 1.417 " ...it's a beast
Comparison:
Ford Toploader 1 1/16 input (1.0625)
Muncie M22 1 1/8 (1.125)
Chris
Re: 4 Speed -- What would you do / Choose? [Re: rabid scott] #263555
03/25/09 09:45 PM
03/25/09 09:45 PM
calif
cupcake Offline
cupcake  Offline
calif
just put the tko 600 in forget bout that old rattlin 833 truck trans
Re: 4 Speed -- What would you do / Choose? [Re: rabid scott] #263556
03/25/09 10:42 PM
03/25/09 10:42 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Well, then I would prefer a 1 1/8" 23 spline...
Re: 4 Speed -- What would you do / Choose? [Re: rabid scott] #263557
03/26/09 12:23 AM
03/26/09 12:23 AM
Oklahoma City
Spraygoon Offline
Spraygoon  Offline
Oklahoma City
I have a n 18 spline in a 70 Cuda (amen to that third gear thing) with a 440 6 pack. I also have a 64 Fury with a 23 spline behind a mild 440. Beleive me they are two different animals and its not just shifter arm length. Not real sure what the internal differences are but the 23 spline is much more enjoyable and easier to drive. They do have different clutches Old style Borg and Beck in the Cuda and a Centerforce in the Fury. ( I like the Centerforce MUCH better!!)I would say your clutch and tire choice should be considered before deciding on a tranny. I think the 23 will work fine.The Cuda has a 3.54 Dana(originaly a 4 bbl car) The Fury tachs about 2800 @70 mph (3.23)TheCudaabout 3000 @70. If the math holds true that would put you car @ 3800 rpm @ 70 mph witha 4.10 gear. I think your real problem is rear gear selection.
Paul
Paul Reber
Re: 4 Speed -- What would you do / Choose? [Re: Spraygoon] #263558
03/26/09 12:26 AM
03/26/09 12:26 AM
Colorado
CuriousYella70 Offline OP
Colorado
Well truth be told, I was wanting to build my Charger similar to that of my father's 70 RR. It's an original 440-6pak, Dana 60 4:10 trak pak car. Thus, the want for an 18spline and a Dana 60 with 4:10 gears -- he's told me story after story about the fun he's had in that car and I thought it'd be cool to have similar B-Body's with the exception of the six pak setup -- might sound stupid but oh well
Re: 4 Speed -- What would you do / Choose? [Re: hemisurfer] #263559
03/26/09 11:08 AM
03/26/09 11:08 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Comparison:
Actually 23 spline is 1", 18 spline is 1-3/16" (1.1875") .toploader is 1-1/16 or 1-3/8 but you are correct on the muncie. 1.417" is the diameter of the throwout bearing sleeve for an 18 spline trans and 1.248 is the diameter of the throwout bearing sleeve on a 23 spline trans.
Re: 4 Speed -- What would you do / Choose? [Re: 446acuda] #263560
03/26/09 12:59 PM
03/26/09 12:59 PM
hemisurfer Offline
hemisurfer  Offline
Chris
Re: 4 Speed -- What would you do / Choose? [Re: hemisurfer] #263561
03/26/09 04:50 PM
03/26/09 04:50 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
That chart is correct for the diameter of throwout bearing sleeve part of the front bearing retainer and is not the same as the input shaft spline diameter.
Page 3 of 3 1 2 3
