DOT or NOT? #2634653
03/20/19 12:13 AM
03/20/19 12:13 AM
fullmetaljacket Offline OP
Correct me if I'm wrong, but it seems that certain Bias-ply DOT drag tires are signaling "Not for highway use" on their side walls even though they are advertised as DOT's. Is this an attempt to protect themselves from a suit for such tires being used on the street before and during an accident?
I'm mean, we all know not to drive any of these Bias-ply or Radial stickies in any kind of wet weather, but is this the start of a new trend?
Just wondering because I just inspected my older "Hoosier Quick time Pros" and all they say is DOT on the sidewall by the beads and I seem to remember that the new editions are saying "Not for highway use"
Whats up?
Re: DOT or NOT? [Re: fullmetaljacket] #2634654
03/20/19 12:23 AM
03/20/19 12:23 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Most likely the "Not for highway use" is there to limit any liability by the manufacturer.
'63 Dodge 330
11.19 @ 121 mph
Re: DOT or NOT? [Re: GY3] #2634655
03/20/19 12:31 AM
03/20/19 12:31 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
Yeah I think it is a case of covering their rears. The 275 Pro Radial carries the same warning I believe.
68 Barracuda Formula S 340
Re: DOT or NOT? [Re: Bad340fish] #2634656
03/20/19 12:36 AM
03/20/19 12:36 AM
Funny, but not surprising because my current QTP's have DOT only on their sides. Must have been from an old batch back when. How times change.
Re: DOT or NOT? [Re: Bad340fish] #2634668
03/20/19 03:09 AM
03/20/19 03:09 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If you have M/T Pro Radials they are not DOT approved.
Re: DOT or NOT? [Re: justinp61] #2634678
03/20/19 07:20 AM
03/20/19 07:20 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
If you have M/T Pro Radials thery are not DOT approved.
My ET Street Pro's have the DOT info on them but not sure if that means they are DOT approved?!
'63 Dodge 330
11.19 @ 121 mph
Re: DOT or NOT? [Re: justinp61] #2634682
03/20/19 07:52 AM
03/20/19 07:52 AM
Tulsa OK
Tulsa OK
The 275 Pro is, it has "tread". The Pro Bracket Radials are not, they don't list them in metric sizes just inches.
I do have 28x10.5 Pro Bracket Radials, not DOT but they have been a really good tire and they look new after 100 passes.
Re: DOT or NOT? [Re: Bad340fish] #2634702
03/20/19 08:42 AM
03/20/19 08:42 AM
an8sec70cuda Offline
The M/T 275-60 ET Street Radial Pro does indeed have a big "DOT" on the sidewall. It also has the "not for highway use" label.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: DOT or NOT? [Re: an8sec70cuda] #2634706
03/20/19 08:50 AM
03/20/19 08:50 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Its just a way of creating a tire for a particular class. Hoosier now makes an 8" slick for new SEGA SS class.Who wants an 8" slick but there is a need and a manufacturer is filling it. Everyone is over thinking this.
Re: DOT or NOT? [Re: fullmetaljacket] #2634710
03/20/19 09:07 AM
03/20/19 09:07 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
We are talking race tires here. And as with anything race oriented, there are compromises to be made for street use. Drag race tires are more expensive, don't like wet surfaces, don't last nearly as long, etc. While I am sure that the 'not for hiway use' is butt covering 101, the tires can build up a lot of heat at sustained hiway speeds. I run short distances at hiway speeds with my DRs and know of a lot of other guys that do too and I have not heard of any problems. But running extended distances at hiway speeds is rolling the dice to some extent. It's just not what the tires were designed and built to do.
twocents
Master, again and still
Re: DOT or NOT? [Re: GY3] #2634715
03/20/19 09:17 AM
03/20/19 09:17 AM
GY3. That is exactly the designation on my QTP's, but with none of the "Not for Highway use" signage like yours have.
Just as a friendly reminder to everyone, if ever an accident were to happen on a public road and your supposed DOT tires are not really DOT. It can create a mess. Drive carefully and try and keep clear of wet conditions. If it rains, pull off the road and wait it out.
A friend of mine for not listening to me crashed his car on the highway while wearing a pair of M/T Drag radials coming from a day at the track. The tires had plenty of tread on them but to no avail on a slight uphill 40 % turn. The road was slightly wet and he swung, hit the wall with the front drivers fender, swung again and landed on his passenger quarter, almost destroying a beautiful and fast car. Thank the heavens that he did not hurt anyone else. I had to block two lanes with my Diplomat police package while flashing the lights just so that he could clear himself of further danger on that blind curve.
Re: DOT or NOT? [Re: fullmetaljacket] #2634729
03/20/19 10:05 AM
03/20/19 10:05 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
FMJ getting fresh rubber......in anticipation!
My street tires are the M/T 16.5x31R and has DOT on the tire.Track tire is am M/T 10.5w.The front do not have a dot rating but I have NEVER had anyone look at the fronts.The po-po only look at the rear......
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: DOT or NOT? [Re: hemi-itis] #2634790
03/20/19 12:02 PM
03/20/19 12:02 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Google is your friend. DOT legal, DOT approved and street legal in your particular state are 3 different things. "Not for highway use" is on pretty much every race tire I've ever seen. Kind of like "don't stick your foot under mower" is on every lawnmower.
Re: DOT or NOT? [Re: hemi-itis] #2634800
03/20/19 12:16 PM
03/20/19 12:16 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
UH...YOU GO TO A RADIAL PREPPED TRACK, AND THOSE "STREET" TIRES WILL BE QUICKER THAN THOSE "RACE" TIRES...LOL
....BAD A$$ STREET CAR.....
Re: DOT or NOT? [Re: GY3] #2634845
03/20/19 02:19 PM
03/20/19 02:19 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I stand corrected, Jegs says not dot approved so I went to M/T's site and sure enough they are DOT approved. It also says "The Mickey Thompson ET Street Radial Pro is D.O.T. approved but designed for drag racing use only. NOT FOR STREET USE". So DOT approved, yes, but not for street use. lol
Re: DOT or NOT? [Re: justinp61] #2634868
03/20/19 03:14 PM
03/20/19 03:14 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
This begs the question...what purpose does DOT approve the tire for, then, if not for street use? laugh
Great stuff lol.
Rich H.
Esse Quam Videri
Re: DOT or NOT? [Re: ZIPPY] #2634945
03/20/19 07:44 PM
03/20/19 07:44 PM
hemi-itis Offline
hemi-itis  Offline
Great stuff lol.
To fit into the rules of a race series..........
Re: DOT or NOT? [Re: hemi-itis] #2634986
03/20/19 09:18 PM
03/20/19 09:18 PM
Note how small the DOT letters are embossed on the sides as compared to the "Not for use" letters. Kinda like one set of letters are for the near sided and the others are for the far sighted.
So far, I'm going to look at all the options and see.
If not, I'll go back to the old Pro-Trac's for street use.
Interesting politics playing out on our sidewalls.
Re: DOT or NOT? [Re: fullmetaljacket] #2635003
03/20/19 10:35 PM
03/20/19 10:35 PM
hemi-itis Offline
hemi-itis  Offline
I have had some luck with the bias E/T streets shruggy
Re: DOT or NOT? [Re: hemi-itis] #2635082
03/21/19 08:08 AM
03/21/19 08:08 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Great stuff lol.
The department of transportation approves race equipment?
Guess it's possible.....Had no idea.....
Rich H.
Esse Quam Videri
