275 ET Street Pros on 71 Duster #2634523
03/19/19 06:53 PM
03/19/19 06:53 PM
Ohio
moparjoe360.4 Offline OP
Ohio
I bought a set of 275 /60/15 for my 71 Duster because they’re on sale but I don’t have rims yet. My car has the springs in the stock location and I’m slightly worried about them fitting. We’ve run 275/60/15 Cooper Cobras on a 73 Duster w 15x8 with 4.5bs and the were tight but they fit. Those tires list as a 10.7 section width while the ET Street pro lists as 11.4 section width. I’m just curious if anyone has run the Pros with stock location rear suspension, and what wheel combo they used.
Re: 275 ET Street Pros on 71 Duster [Re: moparjoe360.4] #2634856
03/20/19 02:55 PM
03/20/19 02:55 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I can't speak to if they'll fit, but I went from 275's to 275 Pros, and the pros were much wider.
Re: 275 ET Street Pros on 71 Duster [Re: dizuster] #2634882
03/20/19 03:55 PM
03/20/19 03:55 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
fwiw, back in the day on my 71 Demon I ran a 28.x11.5 hoosier quick time pro (10" tread width) on a 8" weld draglite w 4.5 backspace. Springs in stock location and they fit, but not a ton of room..
2 kids and a dog
Re: 275 ET Street Pros on 71 Duster [Re: TonyS451] #2634893
03/20/19 04:19 PM
03/20/19 04:19 PM
Ohio
Ohio
That gives me hope that I can make them fit. The 11.5 QTP lists as a 11.2 section width.
Re: 275 ET Street Pros on 71 Duster [Re: TonyS451] #2634894
03/20/19 04:20 PM
03/20/19 04:20 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I have the ET Street 275 on my 70, i used a 1/4 inch spacer to keep the tire off the spring
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: 275 ET Street Pros on 71 Duster [Re: moparjoe360.4] #2635506
03/22/19 10:28 AM
03/22/19 10:28 AM
moparx Offline
moparx  Offline
see what wheel the specs were based on. a slightly narrower wheel may pull the sidewall in a bit, allowing you to use that tire.
beer
Re: 275 ET Street Pros on 71 Duster [Re: moparx] #2635653
03/22/19 05:44 PM
03/22/19 05:44 PM
Ohio
Ohio
beer
This is exactly what I’m hoping, they call for a 7.5-9.5 rim width according to Summit. The 73 340 duster we built had Cooper cobra 275/60/15s on an 8” rim with 4.5 B.S and the belly of the tire was 1/4-3/8” from the springs . I’m looking at running stock steel 15x7 Fifth Ave/ Diplomat wheels that have about 4-4 1/4 B.S. if all else fails I’ll move the perches on the 8 3/4 and buy the offset shackle Kit.
Re: 275 ET Street Pros on 71 Duster [Re: moparjoe360.4] #2635766
03/23/19 01:48 AM
03/23/19 01:48 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
These are 275 Pro's a couple years old on 15x8's very snug, I went 1.43 60' with these
Re: 275 ET Street Pros on 71 Duster [Re: moparjoe360.4] #2635866
03/23/19 10:50 AM
03/23/19 10:50 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
They should fit fine. I have them on a set of 15x8" rims with 3.5" back spacing and there's almost 1" of room between the tire and the leaf spring. This is on a 72 Duster, leaf springs in the stock location:
