Page 95 of 159 1 2 93 94 95 96 97 158 159
Re: Paint job on a budget!? CONTINUED..page 44........ #26338
11/24/06 07:42 PM
11/24/06 07:42 PM
toronto canada
69chargeryeehaa Offline OP
toronto canada
that saftey orange i think is a little bright compared to the burnt orange your car was originally, i know the color, my dad's bug was that color originally, my bug was the brighter later orange, the paint i used was really close to the original color of my car, the color of your car if it is the darker red color is not the same orange of my car.
my bug (74) was a arizona car, and completely rust free. but looking at your pic, you really should pull that back window, and cut/weld in new metal.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69chargeryeehaa] #26339
11/24/06 08:13 PM
11/24/06 08:13 PM
Hi Charger. That rust hole has been cut out and a donor piece has been welded in. Do you think a burnt orange is close to the color? Im not sure if its actually a red or a orange color. I found some marine paint that is burnt orange, but its a 2 part urethane enamel. I was reading this paint is really bad for you,but it can be sprayed or rolled on. I wonder if I do it outside with a respirator if this paint would work? I have a url to the paint but im not sure if I can post a url here. Not sure if its allowed
Re: Paint job on a budget!? CONTINUED..page 44........ #26340
11/24/06 08:52 PM
11/24/06 08:52 PM
toronto canada
toronto canada
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69chargeryeehaa] #26341
11/26/06 05:28 PM
11/26/06 05:28 PM
The last post that shows on my computer is from Friday, the 24th. Has nobody posted since then?
Re: Paint job on a budget!? CONTINUED..page 44........ #26342
11/26/06 06:52 PM
11/26/06 06:52 PM
Bakersfield, CA
K
kenzo42 Offline
kenzo42  Offline
K
Bakersfield, CA
I was wondering the same thing. It must be turkey coma.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: kenzo42] #26343
11/26/06 08:57 PM
11/26/06 08:57 PM
hey EXIt, how many coats of the red did u put on to completely cover the color underneath? jw cause im on my 4th coat and i can still see where i sanded down parts, etc, maybe im putting them on too thin? not sure but im mixing the paint 20% spirits, 80% paint. does that seem right?
Re: Paint job on a budget!? CONTINUED..page 44........ #26344
11/26/06 09:35 PM
11/26/06 09:35 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Well, I think I covered most of the car with about 10 coats. For some reason I could never get the dark spots on the roof to be covered. Even after 12 coats I think I could still see the dark areas.
The sides LOOKED ok to me, but only the roof had light on it, so maybe the sides were still showing dark spots too, but I just couldn't see it. not sure.
I think the mixture you're using is much thicker than the one I was using (reason for my having to use so many coats), but I found the thinner it went on, the less orange peel there was. It's a tradeoff - more coats vs. more wetsanding between coats to get rid of orange peel.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26345
11/26/06 10:43 PM
11/26/06 10:43 PM
yah i have 12 coats and i wetsanded and buffed. i too went through a coat and had dark spots so iam going to try to put another coat to cover the spots and then 4 coats of clear then wetsand and buff and see what happends.
Re: Paint job on a budget!? CONTINUED..page 44........ #26346
11/26/06 10:56 PM
11/26/06 10:56 PM
MENAPPI & MYBUICK: What kinds of paint are you using?
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26347
11/26/06 11:03 PM
11/26/06 11:03 PM
Bakersfield, CA
K
kenzo42 Offline
kenzo42  Offline
K
Bakersfield, CA
Exit, were those dark spots from where you primered? Thanks.
Re: Paint job on a budget!? CONTINUED..page 44........ #26348
11/27/06 12:18 AM
11/27/06 12:18 AM
rustolium gloss black
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: kenzo42] #26349
11/27/06 08:43 AM
11/27/06 08:43 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
It was primer, but I'm pretty sure it was original dark brown primer. There were spots on the side of the car where it was dark brown primer also, yet those seemed to get covered OK.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26350
11/27/06 01:19 PM
11/27/06 01:19 PM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
You gotta figure here I am with maybe a few more hours of sanding and prep work and then let the rolling begin. Oh and it is supposed to rain today and this is southern Cal
Fire Red Brightside any reason I should be concerned because I used brown primer? I could use gray primer over it I do have some.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #26351
11/27/06 11:44 PM
11/27/06 11:44 PM
im confused, why wetsand inbetween coats to get rid of orange peel when u can wetsand at the end? i thought the wetsanding in between coats was to get rid of dust? seems kinda pointless to me to wetsand the peel out and then have to redo it after 2 coats...
Re: Paint job on a budget!? CONTINUED..page 44......... #26352
11/28/06 12:05 AM
11/28/06 12:05 AM
Orange County, CA
Jolly_Raj_R Offline
Jolly_Raj_R  Offline
Orange County, CA
did we ever find out about the guy that used the do-it-yerself pearl for his paint? I'm interesting in something more than just solid-color shiny, but I'm not willing to drop $2500-$4500 (recent estimates) just to get decent paint when I can roll it myself for under $1k (with bodywork, mind you)
http://www.paintwithpearl.com/
is the website if I rememebr correctly..
Raj
67 beatercuda
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #26353
11/28/06 12:30 AM
11/28/06 12:30 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
In my experience the brightside covered much better. It only took a couple (albeit thick) coats to cover dark spots when I started using brightside.
What car are you painting? Be sure and post pics..
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Exit1965] #26354
11/28/06 10:24 AM
11/28/06 10:24 AM
Southern, Ca.
69DartGT Offline
moparts member
69DartGT  Offline
moparts member
Southern, Ca.
Exit1965 heres the project before sanding/primer etc.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: 69DartGT] #26355
11/28/06 10:45 AM
11/28/06 10:45 AM
You can barely notice the pearl, but that was with white..i can try some with black to see how it turns out. This looks nothing like clear with pearl tho'. looks just metalliac. A better idea would to just shoot clear with pearl.
Steve
Re: Paint job on a budget!? CONTINUED..page 44........ #26356
11/28/06 03:37 PM
11/28/06 03:37 PM
Pittsburgh
Java Offline
Java  Offline
Pittsburgh
Here is my test piece. This was the first time I have ever really tried to paint/wetsand anything, and the results show.
There are a lot of marks and variations in the paint where I did not wetsand enough. I am not sure if you can see it in these pictures or not, but the scratches from sanding are evident. I used 600 after the first two coats, 800 after the second two, and 1000 after the final two. Any suggestions on how to wetsand better? How do you wetsand the corners and edges? Even though my wetsanding was subpar, I still hit it with some 3M rubbing compound, some polish I had in the garage, and my cheapo single-speed polisher. I was surprised with the shine and smoothness I got. I had very little orange peel. It looks great from 5 feet away.
My camera isn't very good and it was late in the day when I took the pics. The color is Rustoleum Navy Blue.
Re: Paint job on a budget!? CONTINUED..page 44........ [Re: Java] #26357
11/28/06 03:53 PM
11/28/06 03:53 PM
im trying to spray, i have a $100 IR gun and a big compressor, i can't get it to lay flat at all. it comes out of the gun in spirts it seems, it just looks speckled after its layed down, any ideas on why? it looks decent after drying, but not how its supposed to
Steve
