Re: Who makes correct generic looking 440ci tall valve covers
[Re: SattyNoCar]
#2633439
03/16/19 07:12 PM
03/16/19 07:12 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I'm sure with some effort you can find ones cheaper than that.
In the comments for the Summit covers is this gem
"Good valve covers, good quality. Only problem they do not clear aftermarket rocker shaft. "
[Re: SattyNoCar]
#2633465
03/16/19 08:55 PM
03/16/19 08:55 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
"Good valve covers, good quality. Only problem they do not clear aftermarket rocker shaft. " I didn't see that comment at Summit. That seems like it would be an error on the buyer as Summit clearly shows the dimensions of the cover. That's the problem with a lot of comments on Summit's stuff. Operator error. Either they ordered the wrong size, didn't install it correctly or once in a blue moon the part was defective. Been dealing with Summit for 20 years and never had a problem but have seen plenty of people blame them for their own stupidity.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: Centerline]
#2633477
03/16/19 09:31 PM
03/16/19 09:31 PM
Supercuda
About to go away
About to go away
up yours
Not sure how operator error applies to a valve cover fitting or not fitting an aftermarket rocker shaft.
Also int eh comments is the inside dimension, that might help the OP decide if it might work.
[Re: moparx]
#2633608
03/17/19 11:32 AM
03/17/19 11:32 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
what doesn't "fit " ? width ? height ? length ? too much left out. Exactly. Have no idea what problem he is trying to solve. And depending on what the problem is, there are usually ways to solve it without buying new valve covers.
[Re: Texican]
#2634004
03/18/19 11:10 AM
03/18/19 11:10 AM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
I am going to be the guy who talks about what folks did before there were any fancy speed parts.
Take two sets of valve covers, cut the first pair say 2" from the flange, cut the second pair 1" from the flange, then weld or braze the top from the second pair on to the first pair, and presto.
Note I wouldn't actually do this...I would just get something else and wouldn't sweat whether it has a stock appearance quite so much.
I have no logo Indy covers on rpm heads, with comp pro magnum rockers, no clearance issues.
Rich H.
Esse Quam Videri
[Re: Jwilli500]
#2634502
03/19/19 05:29 PM
03/19/19 05:29 PM
Posts: 1,848 South Bend
John Brown
South Bend
Don't remember where I saw this but someone took a pair of the Aluminum Moroso covers and Hammer-and-dollied the "letters" flat then painted 'em. Fullmetaljacket..... It was on the Jenny Craig thread.
[Re: AndyF]
#2634584
03/19/19 08:58 PM
03/19/19 08:58 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
How about these billet valve covers? Do they look stock enough for you? Andy, your covers look super nice & would look great on my 383.
[Re: Triggerfish]
#2634606
03/19/19 09:39 PM
03/19/19 09:39 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have the Summit brand cast valve covers with RAS shafts and holdowns on Indy EZ heads and they fit with some slight trimming and enlarging the holes Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2634970
03/20/19 08:40 PM
03/20/19 08:40 PM
BSB67
Prospect, PA
[quote=fourgearsavoy]I have the Summit brand cast valve covers with RAS shafts and holdowns on Indy EZ heads and they fit with some slight trimming and enlarging the holes Gus [/quote I've only used factory valve covers and have used Isky, Crower, Crane ductile iron, Cane Aluminum 1.6, and Comp Pro Magnums rockers with only minor baffle work to the VC.
[Re: Triggerfish]
#2634995
03/20/19 10:08 PM
03/20/19 10:08 PM
Posts: 171 IL
BlwnCrcab
IL
How about these billet valve covers? Do they look stock enough for you? Andy, your covers look super nice & would look great on my 383. Andy what brand are the valve covers?
