Page 2 of 3 1 2 3
Re: Think I fried a fresh 727 on break in [Re: 540challenger] #2634382
03/19/19 11:52 AM
03/19/19 11:52 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Originally Posted by 540challenger
When the deep pan was installed did u put a filter extension on it because if u didn't like said already u will need more fluid
I did install an extension on the pickup in the deep pan if I remember right it was a triangular chunk of aluminum sandwiched by gaskets. It is supposed to be a +2 quart pan.
I fired her up this am and added two more quarts of fluid which surprisingly didn’t just over fill up into the dipstick tube. Now it has 9 quarts of trick shift in it. I sat for 5 mins or so slowly shifting from reverse to 1 and back. Nothin. Tires didn’t move at all, no feeling of going into any gear, pan and cooler lines are cold
Re: Think I fried a fresh 727 on break in [Re: MR_P_BODY] #2634389
03/19/19 12:13 PM
03/19/19 12:13 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Originally Posted by MR_P_BODY
Are the 4 converter bolts in that couple it to the trans
wave
Yes. I remember being amazed at how small the bolts were compared to the bolts holding the flex plate to the crankshaft.
Re: Think I fried a fresh 727 on break in [Re: radar] #2634395
03/19/19 12:32 PM
03/19/19 12:32 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
as stated front band servo piston is installed wrong, also looks like band adjustment is backed all the way out?
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Think I fried a fresh 727 on break in [Re: 440lebaron] #2634415
03/19/19 01:12 PM
03/19/19 01:12 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If dumping more oil in it didn't result in any improvement, then you can assume it has to come back out. So many small (or large) details could be incorrect, at some point you'll have to have someone look at it. I wouldn't take it apart and then take it somewhere else in pieces.
Re: Think I fried a fresh 727 on break in [Re: radar] #2634427
03/19/19 01:45 PM
03/19/19 01:45 PM
Me thinks you knock the two drive lugs off the front pump while installing the converter, I did that the first time I installed a converter in my 1962 Plymouth Fury with the 727 whiney scope shruggy I had not understood how hard it is to get the dang converter to install correctly on all the 727 confused Mine dropped down once, it needs to drop down three times usually shruggy
I stand the tranny up so I can drop the converter in and twist and rotate it so it drops down all the way, sometimes it goes good and other times it does not shruggy
I do start off by aligning the drive lugs in the pump so they are both at zero and 180 degrees on the front shafts and align the slot in the converter the same wayup
I found out that by using a straight flat edge like a carpenter square on the front of the tranny bell housing flange that with the converter lugs need to be around .750, 3/4 inch from the converter side of the flat edge scope
if it won't pump fluid in neutral it is probably the front pump drive teeth broken whiney scope
Let us know what you find
Re: Think I fried a fresh 727 on break in [Re: Cab_Burge] #2634441
03/19/19 02:09 PM
03/19/19 02:09 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Here's my trick. Go into the pump with a pick type tool and align the pump ears to 12 and 6 o'clock. Spin the converter in your hands to get the notches to 12 and 6 also, and slide it straight in. Usually it takes a bit of gentle in and out without spinning the converter very far from that position to get it to drop. If it's contrary, you might have to start over a few times. Easiest way I've found.
Re: Think I fried a fresh 727 on break in [Re: CMcAllister] #2634473
03/19/19 03:49 PM
03/19/19 03:49 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Ok so it could be a few obvious things but she’s coming back out. I think that pic is from when I had the kickdown piston installed upside down and took pics to compare to my books. I didn’t take a lot of pics doing the trans since I was usually covered in sticky blue grease. I’ll report back once I have the trans dropped...
I’m still curious to know what to look for in the converter- if the snout is ok where it turns the pump how do I know if I smoked the guts of it? It is a holeshot which was like $400- a cheap converter but still ouch
Re: Think I fried a fresh 727 on break in [Re: radar] #2634475
03/19/19 03:54 PM
03/19/19 03:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Burnt = fluid discolored and smells like death. Parts broken or torn up = jewelry store in the pan. Neither of these = parts missing or installed wrong or something broken clean.
Re: Think I fried a fresh 727 on break in [Re: CMcAllister] #2634487
03/19/19 04:33 PM
03/19/19 04:33 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Ok so I have a chance of saving the converter if the pump drive isn’t sheared or something. I didn’t know if it could be fried from spinning dry
Thanks!
Re: Think I fried a fresh 727 on break in [Re: radar] #2634493
03/19/19 04:49 PM
03/19/19 04:49 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
I’m 80% sure I got the converter to drop in- tipping the trans down, spinning it, and trying it clocked a bunch of ways took a couple hours but I remember pulling it slightly back out to touch the flexplate when I bolted it up. And of course I forgot to mark the offset hole so it took a few tries spinning the motor around before all 4 bolts went in...
Assuming the pump drive is engaged- Is there a good chance the problem could be either in the valve body or accessable once the valve body was dropped? I’d hate to pull the trans to find out it was something that could be fixed just dropping the pan. Plus I sprung for a pan with a drain and a nice one piece rubber gasket so dropping the valve body is pretty easy and I can get a brand new oil pan to catch the atf and reuse it- dipstick reads super clean not burnt
Re: Think I fried a fresh 727 on break in [Re: radar] #2634495
03/19/19 05:02 PM
03/19/19 05:02 PM
A727Tflite Offline
A727Tflite  Offline
Read my PM about diagnosing your issue further.
You can’t burn the converter up doing what you have done so far.
If broken drive lugs - you may have scored up the pump rotor pocket but you won’t know either until you get it apart.
Re: Think I fried a fresh 727 on break in [Re: A727Tflite] #2634532
03/19/19 07:06 PM
03/19/19 07:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted by Transman
The book is wrong and somehow I made a typo. My earlier post should say “ ,not park”.
You have to be in neutral to get any substantial flow out of the cooler line.
You will be there forever trying to fill the converter in park.
The manual valve supplied in the TF-2 kit allows converter fill in Park. Symptoms point to failed pump drive lugs.
Re: Think I fried a fresh 727 on break in [Re: John_Kunkel] #2634725
03/20/19 09:54 AM
03/20/19 09:54 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Once I pull the valve body is it possible to cover the pump suction port with my hand while cranking with the ignition off to see if it is pulling? That way I would know for sure if it’s the pump or something else.
Re: Think I fried a fresh 727 on break in [Re: radar] #2634783
03/20/19 11:54 AM
03/20/19 11:54 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
see tech archive on moparts for air checking servos and drums with valve body down
gary
Re: Think I fried a fresh 727 on break in [Re: radar] #2634784
03/20/19 11:57 AM
03/20/19 11:57 AM
A727Tflite Offline
A727Tflite  Offline
Go through the valve body, if all good - a better test for the pump is reinstall the valve body and pan then add all the fluid in to the trans.
Note how high the fluid is on the dipstick before starting the engine.
Start the engine and run it for a few minutes and check again. If the fluid level is lower then the pump is working.
When you pull the valve body the converter will lose some of it’s fluid. Upon startup you will fill the converter which will lower the fluid - if the pump is working.
Once you get the valve body apart take a pic and post it of the end of the regulator valve - the end that sticks out once installed in the valve body.
Re: Think I fried a fresh 727 on break in [Re: radar] #2634804
03/20/19 12:23 PM
03/20/19 12:23 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Only 7 qts thats not near enough to fill am trans and converter takes more like 12......I's add more fluids before pulling anything apart
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Think I fried a fresh 727 on break in [Re: HemiRick] #2634830
03/20/19 01:30 PM
03/20/19 01:30 PM
West Michigan, Usa.
K
killersix Offline
killersix  Offline
K
West Michigan, Usa.
Do you have a stock valve body or a core trans to get a valve body to swap it with? As you said you have a drain plug and reusable gasket. If you did something wrong when you did the valve body you probably won't know what it is by looking at it. Ten bolts when the pan is off, air test the case ports and try the stock one. All your out is a little time and oily hands.
Re: Think I fried a fresh 727 on break in [Re: killersix] #2634857
03/20/19 02:57 PM
03/20/19 02:57 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Warning: staggering stupidity below. File under “who sold this guy tools?!”
Welp after figuring out that I had to roll the rear wheels with my foot to free the parking pawl I got the valve body on the bench. Guess what? I found something RIGHT AWAY. Oh man this is so dumb I’m embarrassed. My filter extension was on backward.
I remember fiddling with them and I know exactly how I managed to not pay attention to such a simple step- there are three holes in the filter and extension block for the deep pan and one is offset. I think I assembled the filter to the extension block with the gaskets and long screws and spun it around until all 3 screws found threaded holes to start into by hand. I stupidly assumed that the offset bolts would make it only install one way- the shape of the block makes kind of an optical illusion that the middle screw is closer to one of the others.
Well apparently it is possible to install backwards. Not being familiar with the auto I didn’t look thru the extension block to be sure it lined up with something.
I’m not going to beat myself up too bad I’m just happy that a pint fell out of the trans with the VB removed. Maybe it sucked enough fluid to lube things a tiny bit even if it had no pressure. There was a tiny drip when I pulled a cooler line. The fluid is clear and there is nothing burnt or shaved into the pan.
What’s even funnier is that if I had went ahead and filled it until the VB was fully submerged it probably would have started working until it made and ate enough dirt to clog something from filterless running.
Oh man this is the cheapest fix ever. I guess the lesson is don’t take anything for granted and double check everything even dumb stuff that barely requires instruction.
Re: Think I fried a fresh 727 on break in [Re: radar] #2634861
03/20/19 03:01 PM
03/20/19 03:01 PM
Welcome to the club on how to become a expert on fixing Mopars whistling grin
Re: Think I fried a fresh 727 on break in [Re: Cab_Burge] #2634878
03/20/19 03:38 PM
03/20/19 03:38 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Thanks Cab!
I’d rather feel dumb than broke any day
Page 2 of 3 1 2 3
