New Product: Hellcat Intercooler Manifolds - Billet AN #2634133
03/18/19 06:04 PM
03/18/19 06:04 PM
Woodstock, IL
Schwartz Perf Offline OP
Woodstock, IL
(Mods please put this in new products forum)
Hey all,
Just wanted to share a product we developed for the Hellcat & Demon supercharger that makes swapping a little easier.
Ours uses #10 AN ORB fittings so you can convert to AN if you want, and run it out of either side!
Meaning, you could have the inlet & outlet on different sides, or both on the driver's side if you want.
We also integrate 1/8 NPT holes into the top of them so you can stick the factory bleeder in either side.
Additionally we have a special fitting for the factory fluid temp sensor, that you can also stick on either side depending on your fluid routing or clearances.
Overall dimensions are approx 1.5" shorter than stock due to the sensor sticking out on the passenger side.
The driver's side dimensions are about the same as stock.
We offer a pair of connecting hoses as well. We don't have any outlet fittings included, because you may want a 90 degree, 45, straight, we have no idea what you want smile.
Just a little back story... We're currently building a 67 Barracuda with a Hellcat engine and the engine bays are smaller front to back than E/B bodies.. so I thought up this design and had our engineers draw it up! Few days later we had a 3D printed test unit, made some adjustments, and went into production. In my opinion, these are a MUST on any Hellcat swapped ride and have the ultimate flexibility!
See the pictures below. We have sold a number of these since our batch was completed last August, had them on a car at SEMA, and if you guys have seen that Hellcat Miata on Youtube that's going on right now, they have a set too!
They're in stock and ready to ship!
For more info or to order, visit this link: SCHWARTZ PERFORMANCE BILLET HELLCAT INTERCOOLER ADAPTERS
Schwartz Performance Inc: The Leader in Bolt-In Muscle Car Chassis for Mopar / Ford / GM.
Check out www.MoparChassis.com for our bolt-in Mopar Unibody offerings.
We offer products for hundreds of companies including Mopar Performance, Milodon, Billet Specialties, Vintage Air, Stainless Works, Tremec, Silver Sport Transmissions, Forgeline, US Mags, and MANY more!
Re: New Product: Hellcat Intercooler Manifolds - Billet AN [Re: Schwartz Perf] #2634549
03/19/19 07:51 PM
03/19/19 07:51 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Doesnt someone already make these already????
Re: New Product: Hellcat Intercooler Manifolds - Billet AN [Re: johnscudashop] #2634638
03/19/19 10:58 PM
03/19/19 10:58 PM
Woodstock, IL
Woodstock, IL
There are similar products on the market since we designed ours, but not with our water temp sensor adapter and universal design.
Re: New Product: Hellcat Intercooler Manifolds - Billet AN [Re: Schwartz Perf] #2634677
03/20/19 07:19 AM
03/20/19 07:19 AM
USA
hudsonhornet7x Offline
USA
Looks to be a well designed piece, thank you for posting this.
Re: New Product: Hellcat Intercooler Manifolds - Billet AN [Re: hudsonhornet7x] #2637722
03/27/19 01:41 PM
03/27/19 01:41 PM
Northern California
B5 Classic Offline
B5 Classic  Offline
Northern California
Can you tell us the dimension from the rear mounting face of the blower to the rear face of your manifold?
Thank you
Re: New Product: Hellcat Intercooler Manifolds - Billet AN [Re: B5 Classic] #2650170
04/29/19 11:12 AM
04/29/19 11:12 AM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
Ill can measure for you in a couple days. I just ordered this set-up for the Charger were building.
Definitely needed, broke the sensor off last night test fitting.
Re: New Product: Hellcat Intercooler Manifolds - Billet AN [Re: Schwartz Perf] #2650199
04/29/19 12:46 PM
04/29/19 12:46 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
There were similar products on the market BEFORE you designed yours....
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: New Product: Hellcat Intercooler Manifolds - Billet AN [Re: B5 Classic] #2650201
04/29/19 12:47 PM
04/29/19 12:47 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Thank you
The answer is 1.75". There are products on the market that are lower profile than that.
SDG Motorsports
Re: New Product: Hellcat Intercooler Manifolds - Billet AN [Re: johnscudashop] #2650660
04/30/19 08:25 PM
04/30/19 08:25 PM
IL
knyech1 Offline
knyech1  Offline
IL
The correct answer was “yes, someone does, and we copied them”.
SDG Motorsports invented them and was the first to go to market.
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: New Product: Hellcat Intercooler Manifolds - Billet AN [Re: knyech1] #2650690
04/30/19 10:02 PM
04/30/19 10:02 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Yep
Alan Jones
Re: New Product: Hellcat Intercooler Manifolds - Billet AN [Re: LA360] #2650830
05/01/19 11:50 AM
05/01/19 11:50 AM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Yep
I'll 3rd that
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
