Best place for a drive shaft. #2632627
03/14/19 12:39 PM
03/14/19 12:39 PM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
I am getting ready to install the od transmission in my truck.
Where is the best place to order a drive shaft from, best priced ,quickest delivery?
Nobody around me is open when I have the time.
Re: Best place for a drive shaft. [Re: moparborn] #2632683
03/14/19 03:29 PM
03/14/19 03:29 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Dennys driveshaft for me, local guys either screw it up or charge more.
Re: Best place for a drive shaft. [Re: moparborn] #2632701
03/14/19 04:17 PM
03/14/19 04:17 PM
New York
DartS Offline
DartS  Offline
New York
Dennys.
Re: Best place for a drive shaft. [Re: moparborn] #2632708
03/14/19 04:39 PM
03/14/19 04:39 PM
Texas
rustyr Offline
rustyr  Offline
Texas
Denny's. A little on the expensive side but you get what you pay for.
Re: Best place for a drive shaft. [Re: moparborn] #2632709
03/14/19 04:43 PM
03/14/19 04:43 PM
CA
crackedback Offline
crackedback  Offline
CA
Check Tattons Driveshafts in Utah. I've ordered a couple from him.
https://www.tattonsdrivelines.com/
I got some 3" with 1350 ends/spicer solid joints for in the 225 range delivered iirc
Re: Best place for a drive shaft. [Re: crackedback] #2632718
03/14/19 05:07 PM
03/14/19 05:07 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Only bought one but it was Dennys.Quick service and was right on after it was ordered.It was beat on for at least 8 or 9 years till my son sold the car.Ill but another when I need one from dennys.rocky
Chrysler Firepower
Re: Best place for a drive shaft. [Re: moparborn] #2632744
03/14/19 06:21 PM
03/14/19 06:21 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Re: Best place for a drive shaft. [Re: moparborn] #2632751
03/14/19 06:36 PM
03/14/19 06:36 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I actually get mine made at the local implement shop.
I supply the ends and dimensions and they make 'em up.
Of course I live out in farm country so that is an easy place for me to find.
I have mechanical Aptitude.
I can screw up anything.
Re: Best place for a drive shaft. [Re: bboogieart] #2632777
03/14/19 07:51 PM
03/14/19 07:51 PM
5thAve Offline
5thAve  Offline
Check local shops. Im not in an overly big area yet we have at least two truck shops around that do that kind of work and probably not too hard to find more if someone was willing to drive an hour or two away.
EDIT:SInce you can't make yourself available when your local places are open see if they will deliver or if they will take instruction from you over the phone if you get someone to do the drop off/pickup.
Re: Best place for a drive shaft. [Re: 5thAve] #2632779
03/14/19 07:55 PM
03/14/19 07:55 PM
NE
moparpoolman Offline
NE
PST Precision Shaft Technologies. Fast turnaround and reasonably priced.
http://pstds.com/
Re: Best place for a drive shaft. [Re: moparpoolman] #2632815
03/14/19 09:39 PM
03/14/19 09:39 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted by moparpoolman
reasonably priced.
Care to elaborate?
I would be more than willing to go that route if it is indeed reasonable.
I'm currently paying less than $100.oo for this service.
Re: Best place for a drive shaft. [Re: moparborn] #2633262
03/16/19 10:30 AM
03/16/19 10:30 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have a Mark Williams 3.5" chromoly driveshaft with 1350 U-Joints. it was $498 for the driveshaft and $204 for the transmission yoke.
No vibration at all. Might be overkill for a mild build, but it works for me.
Re: Best place for a drive shaft. [Re: 451Mopar] #2633265
03/16/19 10:37 AM
03/16/19 10:37 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Without defining "best place" all answers are moot.
Is "best place" one that can handle the entire job with zero effort on your part?
Is "best place" one that has the cheapest price?
Is "best place" one that is local and you can easily go there with any questions or issues you have and get a personal resolution?
Best place means nothing without context.
Don't be the exception.
Re: Best place for a drive shaft. [Re: Supercuda] #2633340
03/16/19 01:00 PM
03/16/19 01:00 PM
moparx Offline
moparx  Offline
and if being made for use behind an OD transmission with 3.73 up gear set, high speed balancing is a must in my opinion. most implement and/or big truck places do only low [1000rpm or MUCH lower] RPM balancing. my one buddy had 3 different new shafts build by 3 different implement/truck places, all balanced, and complained about vibration issues. we unhooked everything including the engine, wheels/tires/brake drums, checked runout of both yokes and the shaft tube, plus runout on the transmission input and output shafts, and ALL of these were A-OK.
everything traced back to driveshaft balance. all three shops balanced the shaft[s] at 450-650rpm.
combo was GM LT1/700R4/3.92r&p with 27" diameter tires.
and yes, the pinion angle was spot on.
just my experience and opinion.
beer
Re: Best place for a drive shaft. [Re: moparx] #2633359
03/16/19 01:44 PM
03/16/19 01:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yep, and if it's behind a 1000hp LS or Hemi it had better be extra stout. Your usually farm/implement shop isn't going to be expert at that either.
So best place really depends
Re: Best place for a drive shaft. [Re: Supercuda] #2633400
03/16/19 03:49 PM
03/16/19 03:49 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Got mine through American Powertrain. 1350 joints. Perfect to the measurements I supplied. Works fine.
383, Hemi 4-Speed, AlterKtion, D60
Re: Best place for a drive shaft. [Re: moparborn] #2633832
03/17/19 08:40 PM
03/17/19 08:40 PM
waynesboro va
jonesboys Offline
jonesboys  Offline
waynesboro va
Strange Engineering ordered thru Dr Diff chrome moly new trans yoke 29 spline 1350 joints installed balanced shipped 365.00 7 to 10 days
Re: Best place for a drive shaft. [Re: jonesboys] #2633838
03/17/19 08:58 PM
03/17/19 08:58 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
I ordered my Strange Engineering driveshaft and it was worth every penny. If I didn't have a bunch of Summit bucks I would have ordered one through Doctordiff. It's hard to beat the price on a CM 3" drive shaft with 1350 joints and forged yokes.
Get the PDF from Cass's website and place your order through him you wont be disappointed twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best place for a drive shaft. [Re: fourgearsavoy] #2634101
03/18/19 03:56 PM
03/18/19 03:56 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I had my local Inland Truck replace the splined ends on my W200 truck drivelines. Screwed all of them up. Balancing issues and alignment issues with the yokes. Multiple trips back for reworks that I had to pay for as I was asking for something better than their "standard" procedures.
