Best rebuild kit for 850 QF Tech carb?
#2633808
03/17/19 07:43 PM
03/17/19 07:43 PM
Posts: 1,032 illinois
bigblk66_coronet
illinois
My Quick Fuels Technology 850 dp needs to have a kit put in it. Doing weird stuff last year and its 8 years old so im figuring it needs a kit put in it. What is the best kit to go with ? Just want to freshen it up . Anyone? thanks Joe
66 Dodge Coronet 500
440w/727
11:10 30 over 440 w/292 purple shaft,stock Eddy heads,3:23,full exhaust
Best ET. 12.38 @110 in street trim
Re: Best rebuild kit for 850 QF Tech carb?
[Re: bigblk66_coronet]
#2633823
03/17/19 08:18 PM
03/17/19 08:18 PM
RapidRobert
A carb specialist said do NOT use a "Tomco" kit. Define weird.
#2633922
03/18/19 07:24 AM
03/18/19 07:24 AM
BradH
"Doing weird stuff" doesn't explain much, but it could mean the carb needs to be inspected for blocked air bleeds and fuel circuits, especially if your fuel contains ethanol. If you notice any corrosion when you do the complete disassembly, that's an obvious sign a simple gasket job won't be enough.
You can get AED kits that range from the basic gaskets up to kits that include new hardware, depending upon what you need to replace.
