440 Valve Seal - Is this right? #2633397
03/16/19 03:32 PM
03/16/19 03:32 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Having a problem with excessive blue smoke at startup (eventually goes away) and notice it again with a hard acceleration after off-gas cruising to a stop. Took valve cover off and noticed valve seals are “up” on the valve..see picture. Is this normal? Thanks Guys!
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: 440 Valve Seal - Is this right? [Re: Plum440] #2633407
03/16/19 04:20 PM
03/16/19 04:20 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think after things get moving it stays down but there are better seals I think.How are the plugs?
Re: 440 Valve Seal - Is this right? [Re: Clanton] #2633408
03/16/19 04:45 PM
03/16/19 04:45 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Those umbrella seals move with the valves so that is normal. The valves need some lubrication or they would lock up. If you're getting a lot of smoke your guides are most likely getting worn beyond spec.
Re: 440 Valve Seal - Is this right? [Re: GODSCOUNTRY340] #2633418
03/16/19 05:32 PM
03/16/19 05:32 PM
iagree
Pull one of the plugs and see if they are shiny or dull scope If shiny there is oil on them, if dull look some where else for the problem wrench
Re: 440 Valve Seal - Is this right? [Re: Clanton] #2633420
03/16/19 05:39 PM
03/16/19 05:39 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Plugs are good. Tan and normal except for #8.
A couple of Jeeps…
Re: 440 Valve Seal - Is this right? [Re: Plum440] #2633422
03/16/19 05:43 PM
03/16/19 05:43 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Thanks all for the replies. I’ll keep digging....
A couple of Jeeps…
Re: 440 Valve Seal - Is this right? [Re: Plum440] #2633427
03/16/19 05:55 PM
03/16/19 05:55 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
try the big block chevy umbrella. they are a little longer than the mopar umbrella and I prefer them. also, it looks like your using the later b-engine "umbrellas"; they're too short.
Re: 440 Valve Seal - Is this right? [Re: lewtot184] #2633428
03/16/19 06:11 PM
03/16/19 06:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Look to see if the intake valves have those same seals, or if they’re longer umbrellas, or the positive style seal.
The short umbrellas are for ex use only, and if the guide clearance is on the loose side, you’ll get some smoke on start up.
Re: 440 Valve Seal - Is this right? [Re: fast68plymouth] #2633435
03/16/19 06:48 PM
03/16/19 06:48 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Listen to "fast". The taller seals are indeed the intake seals. Them shortys I don't even like using on exhaust. But I worked on many many Gm's, buicks especially that had a shield inside of springs and some used NO exhaust stem seals.
Re: 440 Valve Seal - Is this right? [Re: buildanother] #2633449
03/16/19 07:55 PM
03/16/19 07:55 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I once had a leak at the intake gasket that had similar issues as yours.
Re: 440 Valve Seal - Is this right? [Re: mopars4ever] #2633558
03/17/19 09:51 AM
03/17/19 09:51 AM
The exhaust valve seals are shorter because the exhaust valves need more lubrication than the intake valves. Exhaust valves get a lot hotter than intake valves and there is no vacuum pull on the exhaust like the intake. The vacuum pull on the intake helps pull some oil between the stem and guide to help lubricate, there is no vacuum pull on the exhaust side so Chrysler made the seal shorter to help get a little more oil to the exhaust valve guides so they don't seize. I wouldn't recommend using the tall seals on the exhaust valves or you'll get worn out guides and/or sticking valves, they need more oil than the intake valves.
Re: 440 Valve Seal - Is this right? [Re: mopars4ever] #2633573
03/17/19 10:20 AM
03/17/19 10:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
By the looks of it the seal diameter may be to large for the spring. The seal shouldn't contact the inner portion of the spring.
Doug
Re: 440 Valve Seal - Is this right? [Re: dvw] #2633582
03/17/19 10:37 AM
03/17/19 10:37 AM
So. Burlington, Vt.
So. Burlington, Vt.
I’m pretty sure up until early/mid-70’s that “from the factory” the BB heads had the long umbrella seals on both intake and exhaust.
Someone here probably knows more about that than I do.
Re: 440 Valve Seal - Is this right? [Re: fast68plymouth] #2633594
03/17/19 10:57 AM
03/17/19 10:57 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
'452's had the short "umbrella" for the exhaust; if you want to call it an umbrella, and the "positive" push on for the intake. what I call the standard umbrella is noticeably longer than what's in the picture. the bb chevy is just about 1/8" longer than the standard mopar umbrella and I use them. looking at the picture I wonder if that's an aftermarket retainer? if so it may be clobbering the intake seals with a performance cam. I do see performance springs so there may be more to the story than the OP has stated.
Re: 440 Valve Seal - Is this right? [Re: lewtot184] #2633609
03/17/19 11:33 AM
03/17/19 11:33 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i stepped out in the garage and got some seals out and did some measuring. if the head has an un-trimmed guide boss then there won't be a big difference between the chevy umbrella and the mopar due to the chamfer at the top of the boss. the mopar umbrella is molded to fit the chamfer. when the boss is trimmed a little; removing part or all the chamfer, the chevy umbrella will give more coverage because it is molded flat on the inside. I prefer the most coverage I can get. there's a few things to look at here and as aftermarket parts are used instead of factory more thought needs to be given to coverage. more exposure of the stem/guide will lead to more oil in the chambers when using umbrellas and I've actually had umbrellas work better than some of the so-called positive seals.
Re: 440 Valve Seal - Is this right? [Re: fast68plymouth] #2633640
03/17/19 12:40 PM
03/17/19 12:40 PM
iagree
I never saw two different length valve seals until the after market company like Fel Pro starting selling them shruggy
Re: 440 Valve Seal - Is this right? [Re: lewtot184] #2633642
03/17/19 12:42 PM
03/17/19 12:42 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I haven't used umbrella seals for a while, but if I remember right, some suppliers included a plastic/
Cellophane type protector to put over the valve stem to keep the sharp edges of the lock grooves from
gouging the seal ID on installation.
Maybe a good amount of grease might serve the same purpose.
Just something to consider...Joe
Re: 440 Valve Seal - Is this right? [Re: Plum440] #2633682
03/17/19 01:35 PM
03/17/19 01:35 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Poke the seal with a screwdriver and see if it's pliable. I replaced a bunch of them on cars that sat too long. Hard seals caused the start up smoke and the replacement seals did the trick to solve the issue.
Re: 440 Valve Seal - Is this right? [Re: lewtot184] #2633737
03/17/19 03:04 PM
03/17/19 03:04 PM
So. Burlington, Vt.
So. Burlington, Vt.
The Mopar performance “viton” valve seal package came with 8 short and 8 long umbrellas(P4120492).
In the Fel-Pro catalog the long umbrellas are listed as the “early” style(SS12419).
Since the bottom of the seal is hidden by the spring/damper in the OP’s pic, it’s hard to say for sure which style seal it is, but I thought it seemed like it was the “short” style on that ex valve.
Re: 440 Valve Seal - Is this right? [Re: fast68plymouth] #2633797
03/17/19 07:01 PM
03/17/19 07:01 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
there's a third type of factory seal. it fits the '452 head intake boss. it's a push on neoprene and reminds you of a positive seal.
