Trick Flow sb heads
#2632169
03/13/19 08:28 AM
03/13/19 08:28 AM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
Will be available to buy in a couple of weeks They have been produced and are sitting around assembled at Trick flow They plan to dyno a set yet this month on a 408 test mule. Didnt think to ask Howard how the 408 was setup Heads should be from 1900-22/2300 bucks fully assembled The top range will have quality solid roller springs and ti retainers installed. Intake is going to lag behind by a little bit
Re: Trick Flow sb heads
[Re: cdp]
#2632883
03/15/19 06:08 AM
03/15/19 06:08 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Subscribed...any particular vendor be getting them before anyone else?
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: cudadoug]
#2632936
03/15/19 10:19 AM
03/15/19 10:19 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Subscribed...any particular vendor be getting them before anyone else? I would guess Summit as a mass retailer. They have close ties to TF. You could say that. Try a search for “trickflow.com” and see what pops up in your browser.
[Re: cudadoug]
#2632955
03/15/19 11:01 AM
03/15/19 11:01 AM
Posts: 31,052 Oregon
AndyF
Subscribed...any particular vendor be getting them before anyone else? I would guess Summit as a mass retailer. They have close ties to TF. Yeah, they own them.
[Re: AndyF]
#2633274
03/16/19 10:52 AM
03/16/19 10:52 AM
RapidusMaximus
Weatherford, Texas
Wow...well there ya go...guess that answers that question...lol
[Re: roadrunninMark]
#2635510
03/22/19 10:39 AM
03/22/19 10:39 AM
AndyF
Any update on the release date? Should be soon. We have a set on order and Summit said they would be shipping in April.
[Re: AndyF]
#2635747
03/22/19 11:35 PM
03/22/19 11:35 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
It would be interesting to see a back to back test vs the pro maxx shockers.
A new iron curtain drawn across the 49th parallel
[Re: 67autocross]
#2636169
03/23/19 09:48 PM
03/23/19 09:48 PM
Posts: 300 Willow Spring
dagohman
Willow Spring
It would be interesting to see a back to back test vs the pro maxx shockers. I called Promaxx last week because I was interested in the cnc'd heads. They said 4 to 6 weeks before they would have any sb Mopar heads. Im also curious about the Trick Flows. Maybe they'll be out one day...
[Re: dagohman]
#2636332
03/24/19 11:08 AM
03/24/19 11:08 AM
67autocross
Manitoba Canada
Pro Maxx must have sold out of them, a local shop has a 408 going on the dyno in the next few weeks with them and are shooting for 600hp. The heads look good and CNC work is nice.
[Re: 67autocross]
#2636359
03/24/19 11:45 AM
03/24/19 11:45 AM
B3422W5
Portage,michigan
Pro Maxx must have sold out of them, a local shop has a 408 going on the dyno in the next few weeks with them and are shooting for 600hp. The heads look good and CNC work is nice. Any ported aluminum replacement head better make 600 on a flattop shortblock with some squeeze Even with a healthy flat tappet.
[Re: B3422W5]
#2640131
04/02/19 10:55 AM
04/02/19 10:55 AM
B3422W5
Portage,michigan
They start getting shipped Fri. People will have them in there in hand next week
[Re: B3422W5]
#2640391
04/02/19 08:51 PM
04/02/19 08:51 PM
67autocross
Manitoba Canada
Pro Maxx must have sold out of them, a local shop has a 408 going on the dyno in the next few weeks with them and are shooting for 600hp. The heads look good and CNC work is nice. Any ported aluminum replacement head better make 600 on a flattop shortblock with some squeeze Even with a healthy flat tappet. On our local Dyno I don’t think I know of a pump gas small block that has gone over 600hp unless it had some of the moved push rod W2 or Indy heads on ...I’m assuming if this one can do it with the pro max heads the trick flows should be around the same.
[Re: 67autocross]
#2640468
04/02/19 11:17 PM
04/02/19 11:17 PM
B3422W5
Portage,michigan
Pro Maxx must have sold out of them, a local shop has a 408 going on the dyno in the next few weeks with them and are shooting for 600hp. The heads look good and CNC work is nice. Any ported aluminum replacement head better make 600 on a flattop shortblock with some squeeze Even with a healthy flat tappet. On our local Dyno I don’t think I know of a pump gas small block that has gone over 600hp unless it had some of the moved push rod W2 or Indy heads on ...I’m assuming if this one can do it with the pro max heads the trick flows should be around the same. A zero deck stroker motor with flattops will be well over 12 to 1 with these heads.. it should make over 600 with a suitable cam.
[Re: B3422W5]
#2640475
04/02/19 11:51 PM
04/02/19 11:51 PM
67autocross
Manitoba Canada
Most of the small block builds around here are pump gas stroker 408-416 inch jobs with a max at say 11:1 that make under 600hp...after that they jump up 700hp and up stuff with big heads and aftermarket blocks. I don’t recall anyone I know really building at 12:1 stroker with a stock style head, this is most likely because it would need race gas and not really make a bunch more power....I’m going to see how this pro maxx stroker does on the dyno before I buy a top end for my stroker.
[Re: 67autocross]
#2640499
04/03/19 07:25 AM
04/03/19 07:25 AM
B3422W5
Portage,michigan
Most of the small block builds around here are pump gas stroker 408-416 inch jobs with a max at say 11:1 that make under 600hp...after that they jump up 700hp and up stuff with big heads and aftermarket blocks. I don’t recall anyone I know really building at 12:1 stroker with a stock style head, this is most likely because it would need race gas and not really make a bunch more power....I’m going to see how this pro maxx stroker does on the dyno before I buy a top end for my stroker. A 12.5 to 1 stroker will ET a lot better than than a 10 to 1 stroker. I could care less about having to run race gas. It wont be a daily driver. Might run 100 gallons of fuel through it a summer. Thats700 bucks. Thats putting around town and racing maybe 8 outings a summer
[Re: B3422W5]
#2643382
04/09/19 07:11 PM
04/09/19 07:11 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
IMM has pictures of the new cylinder head on their Fakebook page.
Rich H.
Esse Quam Videri
