Re: A and M body disc brake spindles
[Re: Hemidavey]
#2632925
03/15/19 09:53 AM
03/15/19 09:53 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Yes.IIRC they are taller than the A bodys.I used both on my 65 conversion.Took the A bodys off and used the taller ones.The taller ones gave a better alingnment.Been on for 15 years and no problems.Rocky
Chrysler Firepower
Re: Good deal in Texas
[Re: NachoRT74]
#2633603
03/17/19 11:26 AM
03/17/19 11:26 AM
Posts: 19,405 north of coder
moparx
i have stood the taller spindles side by side, and at most, there may be 7/16" difference, depending on the casting. with the upper balljoint taper machining depth done, it likely would amount to a height difference of around 5/16-3/8" difference, depending on casting length and how the casting was fixtured for machining. add in the tolerance stacking allowed back in those days, plus tire size used in your application, if there is any one contributing thing that would create a visible/measurable height difference, i would say it would be the tire itself. the reason i say this. pick three identical size tires from three different manufacturers. these can have up to one inch difference in height, tread width, and section width, and still meet the manufacturers quality specifications when mounted on the same size [width] wheel. hard to believe, but try it some time. seeing is believing. just my real world experience of way over 50yrs. so, in my opinion, i don't believe the spindles themselves would contribute anything with regards to "lowering" the vehicle ride height by any significant/measurable amount that would be visible to the eye.
[Re: TC@HP2]
#2633761
03/17/19 04:34 PM
03/17/19 04:34 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Oh Ok!!! so the diff being on just top side will make a diff ratious action on UCA. Interesting! I allways have thought the spindle location was diff with both control arms. Sounds logic the diff just on UCA end being the frame rail higher due the isolation!
thanks!
[Re: NachoRT74]
#2633996
03/18/19 11:01 AM
03/18/19 11:01 AM
moparx
yes, the isolators were the reason for the height difference. that said, when the taller spindles are used on the earlier cars, this introduces a different camber curve into the geometry, which will produce arguments and opinions on both sides of good and bad characteristics using this spindle. for 99.999% of the users, this is of no concern, as a good alignment allows them to work perfectly. the other .001% seem to want or need what they want or need. over the years i have done countless conversions using these spindles for myself and others, and by now, i'm sure there are millions and millions of miles traveled without issues. i have never heard, or seen any.
[Re: moparx]
#2634122
03/18/19 05:33 PM
03/18/19 05:33 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
yes, the isolators were the reason for the height difference. I wouldn;t say that. the isolators have no bearing on the relationship between the UCA and the LCA. All they do is isolate the entire front suspension, UCA included, from the frame rails.
[Re: savoy64]
#2634138
03/18/19 06:14 PM
03/18/19 06:14 PM
Supercuda
About to go away
About to go away
up yours
You are probably thinking of the Bigblockdart article
[Re: Hemidavey]
#2634181
03/18/19 08:01 PM
03/18/19 08:01 PM
Posts: 12,078 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have used the taller spindles AND the offset bushings together on many builds and there was never a problem with the alignment. But stock spindles and stock UCA bushings often will not come in.
Master, again and still
[Re: moparx]
#2634290
03/19/19 06:59 AM
03/19/19 06:59 AM
NachoRT74
Valencia, España
yes, the isolators were the reason for the height difference. that said, when the taller spindles are used on the earlier cars, this introduces a different camber curve into the geometry, which will produce arguments and opinions on both sides of good and bad characteristics using this spindle. for 99.999% of the users, this is of no concern, as a good alignment allows them to work perfectly. the other .001% seem to want or need what they want or need. over the years i have done countless conversions using these spindles for myself and others, and by now, i'm sure there are millions and millions of miles traveled without issues. i have never heard, or seen any. So just to be sure and get it clear! The distance between the shaft/bearing ( center of wheel ) and LCA is the same between earliers and laters spindles while te distance difference is actually located between shaft/bearing and UCA. And of course this just affects aligment specs but not the ride height which actually will remain the same being still the same on bottom section of spindle. Now I have a question. Phisically is posible to swap the spindles L to R, but... could this be done to change the calipers indexing for convenience? Visually it seems this is posible without affect anything on geometry or axles distance. Sorry the highjack to the OP, but this could be interesting!
[Re: TC@HP2]
#2634292
03/19/19 07:22 AM
03/19/19 07:22 AM
NachoRT74
Valencia, España
Actually no, these do not lower the car at all compared to other equivilent OEM mopar spindles. They only have an additional 3/8" of material on the top of the spindle that creates slightly altered geometry to the upper control arm. They do not provide any built in drop because the bearing shaft center line relative to the lower joint has not changed dimensionaly. They also weight about a pound and a half less than the pre '76 disc spindles as well, so there is that benefit as well.
Now, with that said, there is a one year only C body spindle that does have a 1" drop built into it. But its lower ball joint bolt pattern is not bolt in compatible with the ABE ball joint pattern. Ok sorry, i jumped out unintentionally this reply... good to know. The RH article says not to swap side to side spindles but making mention just to hose and sway bar deal, however this could still be done for any custom convenience ( by owners decision ) without affect anything on geometry including axle distance on car! Right?
[Re: DaveRS23]
#2634295
03/19/19 07:38 AM
03/19/19 07:38 AM
NachoRT74
Valencia, España
I have used the taller spindles AND the offset bushings together on many builds and there was never a problem with the alignment. But stock spindles and stock UCA bushings often will not come in. Talking about this! Locally all mopars have REALLY bad reputation about front end weakness and aligment troubles. So bad, that ppl tends to remove the stock K frame and modify everything needed to install CHEBBY subframes down stock frame rails ( usually 70s Novas &/or small Malibus on A bodies at least ) Some ppl however use to cut the UCA and elongate them by an inch or so get them outer just right an offset bushing. Some ppl have changed the LCA bushing using brass pieces or even BEARINGS on them due premature failures. I have think this deal is related to oil leaks on engine which damages the rubber &/or tighten up the LCA pivot nut before set the ride height, breaking the bushing out when seting the ride height after tight the nut. Whatever, the question on this is, if have somebody found some problem on frame rails being bent or twisted after all these years causing the aligment issues being the UCA attached to frame rail? Meaning this due the offset bushing existance and now you mention having a similar problem. Need to say locally Mopars have allways abused after all these years. And has being like that since ever! Once again sorry the highjack, but since has being floated out somehow, maybe is time to ask
