Re: Best place for a drive shaft.
[Re: moparborn]
#2632709
03/14/19 04:43 PM
03/14/19 04:43 PM
Posts: 2,081 CA
crackedback
CA
Check Tattons Driveshafts in Utah. I've ordered a couple from him. https://www.tattonsdrivelines.com/I got some 3" with 1350 ends/spicer solid joints for in the 225 range delivered iirc
[Re: crackedback]
#2632718
03/14/19 05:07 PM
03/14/19 05:07 PM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
Only bought one but it was Dennys.Quick service and was right on after it was ordered.It was beat on for at least 8 or 9 years till my son sold the car.Ill but another when I need one from dennys.rocky
Chrysler Firepower
[Re: moparborn]
#2632751
03/14/19 06:36 PM
03/14/19 06:36 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I actually get mine made at the local implement shop. I supply the ends and dimensions and they make 'em up. Of course I live out in farm country so that is an easy place for me to find.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2632777
03/14/19 07:51 PM
03/14/19 07:51 PM
Posts: 4,159 Canada -- Posts: 4034 -Registe...
5thAve
Check local shops. Im not in an overly big area yet we have at least two truck shops around that do that kind of work and probably not too hard to find more if someone was willing to drive an hour or two away.
EDIT:SInce you can't make yourself available when your local places are open see if they will deliver or if they will take instruction from you over the phone if you get someone to do the drop off/pickup.
[Re: moparpoolman]
#2632815
03/14/19 09:39 PM
03/14/19 09:39 PM
bboogieart
Lost and Spaced
Care to elaborate? I would be more than willing to go that route if it is indeed reasonable. I'm currently paying less than $100.oo for this service.
[Re: 451Mopar]
#2633265
03/16/19 10:37 AM
03/16/19 10:37 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Without defining "best place" all answers are moot.
Is "best place" one that can handle the entire job with zero effort on your part?
Is "best place" one that has the cheapest price?
Is "best place" one that is local and you can easily go there with any questions or issues you have and get a personal resolution?
Best place means nothing without context.
[Re: Supercuda]
#2633340
03/16/19 01:00 PM
03/16/19 01:00 PM
Posts: 19,624 north of coder
moparx
and if being made for use behind an OD transmission with 3.73 up gear set, high speed balancing is a must in my opinion. most implement and/or big truck places do only low [1000rpm or MUCH lower] RPM balancing. my one buddy had 3 different new shafts build by 3 different implement/truck places, all balanced, and complained about vibration issues. we unhooked everything including the engine, wheels/tires/brake drums, checked runout of both yokes and the shaft tube, plus runout on the transmission input and output shafts, and ALL of these were A-OK. everything traced back to driveshaft balance. all three shops balanced the shaft[s] at 450-650rpm. combo was GM LT1/700R4/3.92r&p with 27" diameter tires. and yes, the pinion angle was spot on. just my experience and opinion.
[Re: moparx]
#2633359
03/16/19 01:44 PM
03/16/19 01:44 PM
Supercuda
About to go away
About to go away
up yours
Yep, and if it's behind a 1000hp LS or Hemi it had better be extra stout. Your usually farm/implement shop isn't going to be expert at that either.
So best place really depends
[Re: Supercuda]
#2633400
03/16/19 03:49 PM
03/16/19 03:49 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Got mine through American Powertrain. 1350 joints. Perfect to the measurements I supplied. Works fine.
383, Hemi 4-Speed, AlterKtion, D60
[Re: jonesboys]
#2633838
03/17/19 08:58 PM
03/17/19 08:58 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I ordered my Strange Engineering driveshaft and it was worth every penny. If I didn't have a bunch of Summit bucks I would have ordered one through Doctordiff. It's hard to beat the price on a CM 3" drive shaft with 1350 joints and forged yokes. Get the PDF from Cass's website and place your order through him you wont be disappointed Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2634101
03/18/19 03:56 PM
03/18/19 03:56 PM
Posts: 10,758 North Dakota
6PakBee
North Dakota
I had my local Inland Truck replace the splined ends on my W200 truck drivelines. Screwed all of them up. Balancing issues and alignment issues with the yokes. Multiple trips back for reworks that I had to pay for as I was asking for something better than their "standard" procedures.
