A body header question #2632071
03/12/19 09:42 PM
03/12/19 09:42 PM
Midland,Tx
wyldebill Offline OP
Midland,Tx
Hey folks. I don't know when my new engine will be finished, so I was thinking about dropping a milder 400 in my valiant. What I'm curious about, what header can I get away with running? It's a standard port low deck. Aftermarket k member so no torsion bars to get in the way. I cant run the headers for the car. Raised port 2.25 primary. Will a b body header work? This is relatively temporary, so I don't want to buy a tti or spend a ton of money here. Any recommendations? Thanks Bill
Re: A body header question [Re: wyldebill] #2632138
03/13/19 03:57 AM
03/13/19 03:57 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
The biggest problem is the shock mount is in the way for anything with nice flowing primaries. I eventually cut the shock mount down & moved the upper mount onto my cage. Then it was a simple case of make my own headers. If you're still running inner fenders, you're going to be screwed, tight bends that make plug access hard are going to be your nightmare.
Re: A body header question [Re: rebel] #2632415
03/13/19 08:31 PM
03/13/19 08:31 PM
Midland,Tx
Midland,Tx
It still has full inner fenders. I already have my headers for the big motor. Was hoping that a set of off the shelf headers will fit.
Re: A body header question [Re: wyldebill] #2632427
03/13/19 09:05 PM
03/13/19 09:05 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Try a b body header, but be prepared to cut up and move one or more tubes. Buy cheap headers and cut off th collector and cut the flange so you can install one tube at a time. Or get a couple sets of used headers I'm sure you can make a set that way. When done get a slip on collector.
....BAD A$$ STREET CAR.....
Re: A body header question [Re: wyldebill] #2633101
03/15/19 05:36 PM
03/15/19 05:36 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Do some research on the 1 3/4" Hedman B-body headers. Plenty has been writen about them fitting lowdeck abodies with just a few dings unless something has changed recently.
Re: A body header question [Re: 1Fast340] #2633232
03/16/19 08:01 AM
03/16/19 08:01 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Keep old mopars alive.
Re: A body header question [Re: 1Fast340] #2633380
03/16/19 03:04 PM
03/16/19 03:04 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Don't use the "Elite" Headman headers, the # 3 and 7 tubes are a mess, even with a MS box. If you have a rack steering box, this may not matter, twocents
Re: A body header question [Re: Skeptic] #2634818
03/20/19 12:46 PM
03/20/19 12:46 PM
Midland,Tx
Midland,Tx
Thanks for the information guy's. I'll update my findings soon.
