Name that distributor #2631517
03/11/19 06:12 PM
03/11/19 06:12 PM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
Looking for some help in ID’ing a distributor (one on the left). The one on the left has a W1218 printed on the side of it but a google search turns up nothing. I believe it is an MSD but didn’t know if it was an small block or big block. I think there is only a 1/8” difference between the two in the length under the mount. Any help with an actual part number would be great. Just looking to see what it is worth.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Name that distributor [Re: clovis] #2631531
03/11/19 06:51 PM
03/11/19 06:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've seen units like that on Ebay; I think they're made in China, but I could be wrong.
Re: Name that distributor [Re: topside] #2631556
03/11/19 07:36 PM
03/11/19 07:36 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
MSDs are billet. That's a Chinese cast deal you can buy for $50. Shipped.
https://www.ebay.com/itm/Dodge-Chry...Electronic-Distributor-HEI-/252772764128
Re: Name that distributor [Re: CMcAllister] #2631667
03/12/19 01:13 AM
03/12/19 01:13 AM
AndyF Offline
AndyF  Offline
440Source used to sell a distributor that looked like that. They actually worked okay, just really ugly. I think there is an HEI setup inside that hump on the side.
Re: Name that distributor [Re: AndyF] #2631718
03/12/19 08:37 AM
03/12/19 08:37 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I think Davis ( DUI ) did something similar for other brands.........using HEI parts.
They may have done MoPar too , which wouldn't surprise me any more than a design being appropriated by a Chinese operation.
Re: Name that distributor [Re: tubtar] #2631719
03/12/19 08:40 AM
03/12/19 08:40 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I had to look........most of the Davis stuff I see is traditional coil in cap HEI.
I swore I saw one with a side pod arrangement , but maybe it was someone else's.
Re: Name that distributor [Re: tubtar] #2631723
03/12/19 08:51 AM
03/12/19 08:51 AM
an8sec70cuda Offline
That's not a DUI distributor, at least not the type I've seen. Those DUI hei distributors nearly need a hole in the hood to clear them. Absolutely the ugliest distributor made for a mopar.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Name that distributor [Re: an8sec70cuda] #2631780
03/12/19 10:43 AM
03/12/19 10:43 AM
moparx Offline
moparx  Offline
that is a $39.95 imported swap meet special. see 'em all the time. the hump on the side contains a GM four connector HEI module.
beer
Re: Name that distributor [Re: moparx] #2631886
03/12/19 01:25 PM
03/12/19 01:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
To answer the OP's question, $35-40 on ebay if you pay the shipping.
