Engine swap question on late '70's W150
#2630116
03/07/19 08:31 PM
03/07/19 08:31 PM
Posts: 15,855 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'm sure it's been done. What is the difficulty level on going from factory slant six to small block (probably LA 360) on '79 or '80 Power Wagon? On cars you're normally looking at K-frame swap, but on a W150, in order to do it right?
If it were to be on a 4 speed, would gear box bolt up with minor changes, e.g. a bell housing maybe?
I don't mind some available parts purchases, I just don't want heavy welding/modifications.
Thanks.
Facts are stubborn things.
Re: Engine swap question on late '70's W150
[Re: ++MAX WEDGE++]
#2630709
03/09/19 11:41 AM
03/09/19 11:41 AM
Posts: 2,109 Byron, NY
W.I.N. Racing
Byron, NY
If not in a 4X4, you will need to change the coil springs up front. S6 to V8 are different. Unless the low bouncy look is what your going for. No you don't... 440 on /6 springs
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2630711
03/09/19 11:43 AM
03/09/19 11:43 AM
W.I.N. Racing
Byron, NY
[Re: W.I.N. Racing]
#2630861
03/09/19 06:53 PM
03/09/19 06:53 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thanks all for info, and pictures!!!!. Mike, check for PM. It's a divorced transfer case. No I don't want low in front look, but pics posted and info say I don't need to worry
[Re: larrymopar360]
#2631100
03/10/19 02:10 PM
03/10/19 02:10 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
If I knew where to start, and somewhat how to go about it, I'd be willing to sell a couple of my current vehicles and buy the truck I'm looking at, and swap a a non-mds hemi and nag1 trans in this truck. As much as I love the old school stuff, I would love to have the outer appearance of this truck with the performance of a new hemi, along with the quick starting, acceleration, smooth idling, efficiency of a modern hemi with maybe even a/c. I'd truly spend the money if I knew of a local shop that could do this swap RIGHT. I have a good mechanic here in town but he's never down this swap and I have to imagine ALL KINDS of headaches would arise. Wire harness issues, fitment issues with engine and trans, mounts, linkages, etc. But I swear I'd sell off two of my vehicles right now to free the funds. Anyone know of somewhere in the Central Florida area that does these swaps, and is know for excellence? Call my bluff!!! It ain't no bluff
[Re: larrymopar360]
#2631135
03/10/19 04:12 PM
03/10/19 04:12 PM
W.I.N. Racing
Byron, NY
If you want to do a Gen III motor swap the best bet is to buy a complete truck so you have all parts and pieces. then swap components over. In the long run it is cheaper. Is an easy swap ..if you have all the parts
[Re: W.I.N. Racing]
#2631461
03/11/19 02:50 PM
03/11/19 02:50 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
If you want to do a Gen III motor swap the best bet is to buy a complete truck so you have all parts and pieces. then swap components over. In the long run it is cheaper. Is an easy swap ..if you have all the parts I can see that being the case and would probably do so. The keeper truck just popped up first. I figure I'll have a lot less trouble finding the parts truck than the rust free keeper truck I'm looking at. Thanks.
[Re: larrymopar360]
#2632786
03/14/19 08:18 PM
03/14/19 08:18 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Please, please, please, show us the keeper. Then keep us posted. Some folks might want to copy the results.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2633303
03/16/19 12:01 PM
03/16/19 12:01 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Oh thanks for interest! I let it go. I just couldn't pull the trigger and go changing such a cool truck. Let me see if I can find a link for it. I didn't want anyone else to buy it out from under me. Is it wrong to say that?
