Sealing HEMI intake #2629766
03/06/19 08:59 PM
03/06/19 08:59 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
Well, my HEMI is down to repair the many problems left me by the first shop that did the work. While waiting on Diamond to produce the new pistons, I am working on the heads.
I have had problems sealing the intake as many of you have. So I have decided to “O” ring them with Viton o ring material.
Ideal gasket thickness is .031 for port alignment. I am using .093 so that I can ball mill the receiver groove deep enough to hold 2/3 of the O ring and hopefully have the correct height for port alignment.
Have any of you done this? Customer will do the machine work (I sell machine tools for a living) and write a C.N.C. program.
I understand that this is a common practice in Top Fuel and Alchohol. What has been your experience with replacing gaskets with “O” rings?
Re: Sealing HEMI intake [Re: Hemi ragtop] #2629807
03/06/19 10:25 PM
03/06/19 10:25 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I did the blower to intake.It will still push some fuel out the back.
What intake manifold?That would require alotta rubber!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Sealing HEMI intake [Re: hemi-itis] #2629835
03/06/19 11:48 PM
03/06/19 11:48 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Look at FHO's website. They do that. Might give you some ideas. I would want to do something standard. And use off-the-shelf O-rings.
http://forhemisonly.com/
2011 Drag Pak Challenger
Re: Sealing HEMI intake [Re: rickseeman] #2629843
03/06/19 11:59 PM
03/06/19 11:59 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Tim did the heads on my 528. It worked well.
Sheldon
Re: Sealing HEMI intake [Re: hemi-itis] #2629862
03/07/19 06:49 AM
03/07/19 06:49 AM
Tennessee
Tennessee
I’m using a MP “marine intake and have always used silicone on the ends, no leaks
Re: Sealing HEMI intake [Re: Hemi ragtop] #2629873
03/07/19 08:35 AM
03/07/19 08:35 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Do not try to maintain the spacing by elevating the manifold with an incorrect o ring recever groove. You will distort or crack the manifold.
Get the intake to fit flush with no gaskets, then cut the grooves with the dimensions in the document. Static o ring groove.
Re: Sealing HEMI intake [Re: Hemi ragtop] #2629907
03/07/19 10:31 AM
03/07/19 10:31 AM
an8sec70cuda Offline
I haven't had any issues sealing mine up w/ the Superformance gaskets, but I'd love to go with O-rings for the ease of installation. Especially w/ larger than stock ports that require trimming gaskets to fit.
My concern is that my intake manifold has been port matched w/ a standard .060" thick gasket.
Anyone know what FHO charges to do this?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Sealing HEMI intake [Re: Hemi ragtop] #2629979
03/07/19 01:28 PM
03/07/19 01:28 PM
I assembled a blown Hemi motor that had the intake O ringed to start with, I used the stock end cork gaskets to seal the ends with silicone, that worked very well.
The O ring was probably no where near as thick as your wanting to use though, maybe .030 to .045 or so.
IHThs
Re: Sealing HEMI intake [Re: Cab_Burge] #2630219
03/08/19 07:08 AM
03/08/19 07:08 AM
Tennessee
Tennessee
My intake matches the ports with a .032” Gasket. My thought is to have 2/3 of the “O” ring in the groove. So I am looking at .093” material. This should leave about .032 for the intake to seal on.
Re: Sealing HEMI intake [Re: Hemi ragtop] #2630225
03/08/19 08:00 AM
03/08/19 08:00 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Standard o ring cross sectional area is listed in the chart I posted on the far left. My suggestion to you if you are not willing to correct the manifold/ head contact alignment, is to use the chart dimensions for standard o ring sizes and groove depth/ width. Then use the gaskets that you have been using to keep the manifold alignment correct. The o rings will sit on the gasket and fill any void that the gasket can’t.
If you go ahead with your plan, you will create more problems than you solve. The manifold floating on rubber will need constant maintenance/ attention. The manifold must be “clamped” to the head.
Re: Sealing HEMI intake [Re: TRENDZ] #2630298
03/08/19 10:51 AM
03/08/19 10:51 AM
Superfreak
Superfreak
FHO just finished my heads this week. $6575 for the heads and the o-ring was $300 with 40% discount. I would guess that if send your heads in for o-ringing then you would pay the $500
[img]https://i.imgur.com/KOUuSWs.jpg?3[/img]
Re: Sealing HEMI intake [Re: ] #2630306
03/08/19 11:00 AM
03/08/19 11:00 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Pretty. I was wondering, can they do that to any head or do they get Stage V's and leave extra meat in the intake face?
Re: Sealing HEMI intake [Re: rickseeman] #2630309
03/08/19 11:04 AM
03/08/19 11:04 AM
Superfreak
Superfreak
These are Stage V heads and apparently that's all Tim uses. I would imagine he can do other heads.
Re: Sealing HEMI intake [Re: ] #2630317
03/08/19 11:23 AM
03/08/19 11:23 AM
RUNCHARGER Offline
RUNCHARGER  Offline
I had no problems when Tim did mine. However I think if any surface is not perfectly square with the other surfaces you will have more problems than you did with gaskets.
Sheldon
Re: Sealing HEMI intake [Re: rickseeman] #2630433
03/08/19 04:02 PM
03/08/19 04:02 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Those aren't standard street heads, wonder if he can do standard heads?
Re: Sealing HEMI intake [Re: TRENDZ] #2630508
03/08/19 06:57 PM
03/08/19 06:57 PM
Tennessee
Tennessee
I appreciate the suggestions, that is why I posted. Unfortunately I can’t read the chart. As for alignment, I used precious wire of various diameters. At .032” all wires between the intake and head surface were in contact, (alignment)? And the ports matched.
Am I missing something?
Also, I used Superformance gaskets and upon removing the manifold I found no evidence of oil leaking through into the intake ports. I am simply doing this as a precaution.
Re: Sealing HEMI intake [Re: Hemi ragtop] #2630515
03/08/19 07:32 PM
03/08/19 07:32 PM
Superfreak
Superfreak
You said in your OP that you are having problems with the intake leaking.
Re: Sealing HEMI intake [Re: ] #2630643
03/09/19 07:54 AM
03/09/19 07:54 AM
Tennessee
Tennessee
True, The first gaskets I used were Felpro. They allowed oil to “weep” THROUGH the gasket. I went to Superformance. Still had oil in the intake ports. Out of desperation, I used Hondabond sealer and more Superformance gaskets. THAT stopped the leak. However, when I removed the intake this time, I thought I would never get it off.
That is why I want a permanent fix. This is not an isolated problem. HEMI intake leaks are not an uncommon problem. I have read several posts on this forum about this problem. Once it happens, you worry if the intake is sealed. I pulled the carbs and using a bore scope, checked the ports for oil several times. I don’t want to worry about it this go round.
Re: Sealing HEMI intake [Re: Hemi ragtop] #2630937
03/09/19 10:42 PM
03/09/19 10:42 PM
hemi-itis Offline
hemi-itis  Offline
If the intake gasket is leaking enough to see it in the port,after removal you should be able to determine where is was leaking.
As said it is critical to have the surfaces fit perfect for that leak free surface! up
Re: Sealing HEMI intake [Re: hemi-itis] #2633431
03/16/19 06:25 PM
03/16/19 06:25 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Everything you wanted to know about O-rings but were afraid to ask. I used the Parker handbook for 30+ years and had good results with their gland designs. I would use the face seal groove dimensions on page 4-18.
https://www.parker.com/literature/O-Ring%20Division%20Literature/ORD%205700.pdf
Floyd Lippencott IV
