Re: Sealing HEMI intake
[Re: Hemi ragtop]
#2629807
03/06/19 10:25 PM
03/06/19 10:25 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I did the blower to intake.It will still push some fuel out the back. What intake manifold?That would require alotta rubber!
[Re: Hemi ragtop]
#2629873
03/07/19 08:35 AM
03/07/19 08:35 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Do not try to maintain the spacing by elevating the manifold with an incorrect o ring recever groove. You will distort or crack the manifold. Get the intake to fit flush with no gaskets, then cut the grooves with the dimensions in the document. Static o ring groove.
[Re: Hemi ragtop]
#2629907
03/07/19 10:31 AM
03/07/19 10:31 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
I haven't had any issues sealing mine up w/ the Superformance gaskets, but I'd love to go with O-rings for the ease of installation. Especially w/ larger than stock ports that require trimming gaskets to fit. My concern is that my intake manifold has been port matched w/ a standard .060" thick gasket.
Anyone know what FHO charges to do this?
[Re: Hemi ragtop]
#2629979
03/07/19 01:28 PM
03/07/19 01:28 PM
Posts: 43,115 Bend,OR USA
Cab_Burge
I assembled a blown Hemi motor that had the intake O ringed to start with, I used the stock end cork gaskets to seal the ends with silicone, that worked very well. The O ring was probably no where near as thick as your wanting to use though, maybe .030 to .045 or so. IHThs
[Re: Hemi ragtop]
#2630225
03/08/19 08:00 AM
03/08/19 08:00 AM
TRENDZ
Milwaukee WI
Standard o ring cross sectional area is listed in the chart I posted on the far left. My suggestion to you if you are not willing to correct the manifold/ head contact alignment, is to use the chart dimensions for standard o ring sizes and groove depth/ width. Then use the gaskets that you have been using to keep the manifold alignment correct. The o rings will sit on the gasket and fill any void that the gasket can’t. If you go ahead with your plan, you will create more problems than you solve. The manifold floating on rubber will need constant maintenance/ attention. The manifold must be “clamped” to the head.
[Re: TRENDZ]
#2630298
03/08/19 10:51 AM
03/08/19 10:51 AM
Superfreak
Superfreak
FHO just finished my heads this week. $6575 for the heads and the o-ring was $300 with 40% discount. I would guess that if send your heads in for o-ringing then you would pay the $500 [img] https://i.imgur.com/KOUuSWs.jpg?3[/img]
[Re: ]
#2630306
03/08/19 11:00 AM
03/08/19 11:00 AM
Posts: 2,631 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
FHO just finished my heads this week. $6575 for the heads and the o-ring was $300 with 40% discount. I would guess that if send your heads in for o-ringing then you would pay the $500 Pretty. I was wondering, can they do that to any head or do they get Stage V's and leave extra meat in the intake face?
2011 Drag Pak Challenger
[Re: rickseeman]
#2630309
03/08/19 11:04 AM
03/08/19 11:04 AM
Superfreak
Superfreak
These are Stage V heads and apparently that's all Tim uses. I would imagine he can do other heads.
[Re: ]
#2630317
03/08/19 11:23 AM
03/08/19 11:23 AM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I had no problems when Tim did mine. However I think if any surface is not perfectly square with the other surfaces you will have more problems than you did with gaskets.
Sheldon
[Re: Hemi ragtop]
#2630515
03/08/19 07:32 PM
03/08/19 07:32 PM
Superfreak
Superfreak
I appreciate the suggestions, that is why I posted. Unfortunately I can’t read the chart. As for alignment, I used precious wire of various diameters. At .032” all wires between the intake and head surface were in contact, (alignment)? And the ports matched. Am I missing something? Also, I used Superformance gaskets and upon removing the manifold I found no evidence of oil leaking through into the intake ports. I am simply doing this as a precaution. You said in your OP that you are having problems with the intake leaking.
[Re: Hemi ragtop]
#2630937
03/09/19 10:42 PM
03/09/19 10:42 PM
hemi-itis
If the intake gasket is leaking enough to see it in the port,after removal you should be able to determine where is was leaking. As said it is critical to have the surfaces fit perfect for that leak free surface!
