How Were Alt/Power Steering Brackets Originally Painted? #2629059
03/05/19 10:56 AM
03/05/19 10:56 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Were alternator and power steering pump brackets originally spray painted or dipped at the factory?
Re: How Were Alt/Power Steering Brackets Originally Painted? [Re: 44D6PAKCUDA] #2629436
03/05/19 11:44 PM
03/05/19 11:44 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
I seem to recall having runs on my grandfathers power steering mounting brackets which were original to his car so I'd have to assume they were most likely dipped.
inherited a 69 roadrunner from my grand pop.
Re: How Were Alt/Power Steering Brackets Originally Painted? [Re: fuelishnsilly] #2629673
03/06/19 02:53 PM
03/06/19 02:53 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
This NOS one I have is painted right over bare steel.
It is however NOS, or over counter , and may not be same as assembly line installed part
Re: How Were Alt/Power Steering Brackets Originally Painted? [Re: mccannix] #2629675
03/06/19 02:57 PM
03/06/19 02:57 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Oh I guess it was the brackets you were inquiring about.
These are NOS alternator brackets and are painted.... again assembly line may be different .
Re: How Were Alt/Power Steering Brackets Originally Painted? [Re: mccannix] #2629889
03/07/19 09:48 AM
03/07/19 09:48 AM
Western,NY
JEJJ Offline
JEJJ  Offline
Western,NY
"These are NOS alternator brackets and are painted.... again assembly line may be different ."
.....yes Terry, but are they spray painted or dipped in paint? shruggy
Re: How Were Alt/Power Steering Brackets Originally Painted? [Re: JEJJ] #2629897
03/07/19 10:07 AM
03/07/19 10:07 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Well since the OP asked if they were 'spray painted or dipped at the factory', I merely offered my opinion and said what I have are " painted", not dipped..
OK Jim, I should have said these appear SPRAY painted, not brush painted if that is what you are asking.
And I would guess that whatever the finish, it would have been done by the vendor, not at the factory
but then I was not there at the time .
Re: How Were Alt/Power Steering Brackets Originally Painted? [Re: mccannix] #2630121
03/07/19 08:43 PM
03/07/19 08:43 PM
What !!! You were not there at the time Terry ? .And I always thought.... smile Thanks for your replies.Now this other Jim guy that's chiming in,I don't know......
Re: How Were Alt/Power Steering Brackets Originally Painted? [Re: 44D6PAKCUDA] #2630527
03/08/19 07:56 PM
03/08/19 07:56 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Ive never seen anything to indicate to me they were dipped
The pump itself I'm sure was sprayed
Re: How Were Alt/Power Steering Brackets Originally Painted? [Re: gtx6970] #2630608
03/08/19 11:19 PM
03/08/19 11:19 PM
Greenwood Lake, NY
Greenwood Lake, NY
I guess they could have had runs with spray painting also. Depending on how heavy they sprayed it.
