Page 3 of 3 1 2 3
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2630082
03/07/19 06:42 PM
03/07/19 06:42 PM
Italy
Raffaplymouth60 Offline OP
Italy
Guys ... anyone speak for the pulley drive diameter ??? too big ... too vacuum ??
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2630101
03/07/19 07:31 PM
03/07/19 07:31 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
My 2 Cents.... Dont spin the pump over 6000 RPM'S..
My 2 cents on the Vacuum 12-14"
I prefer the 4 Vane Pump. But as long as the one you using will pull whatever vacuum setting you feel you need and it's working and your not having to rebuild the pump all the time. Run it... smile
But like I said. Thats just my point of view. smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2630341
03/08/19 12:19 PM
03/08/19 12:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
66% of engine speed seems to be a happy place for the typical Bracket guy. If you have a higher RPM deal, then 50% of engine speed.
Re: 572 Vacum Pump [Re: racerhog] #2630471
03/08/19 05:34 PM
03/08/19 05:34 PM
Italy
Italy
my pump run at over 7500 because have same pulley on the crank same diameter on the pump ....
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2630494
03/08/19 06:33 PM
03/08/19 06:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
You need to correct that as soon as possible.
Re: 572 Vacum Pump [Re: Cab_Burge] #2630759
03/09/19 01:49 PM
03/09/19 01:49 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Its supposed to be 2 to 1,with the 2(bigger pulley) on the pump.
Re: 572 Vacum Pump [Re: OUTLAWSSAA] #2638192
03/28/19 05:52 PM
03/28/19 05:52 PM
Italy
Italy
New Drive Pulley installed ! solved ! now correct vacuum !
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2638194
03/28/19 05:54 PM
03/28/19 05:54 PM
Italy
Italy
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2638195
03/28/19 05:58 PM
03/28/19 05:58 PM
Italy
Italy
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2638196
03/28/19 05:59 PM
03/28/19 05:59 PM
Italy
Italy
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2638227
03/28/19 07:34 PM
03/28/19 07:34 PM
Texas
RustyM Offline
RustyM  Offline
Texas
Glad you got it sorted, you have beautiful cars.
Re: 572 Vacum Pump [Re: Raffaplymouth60] #2638242
03/28/19 08:22 PM
03/28/19 08:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Engine displacement is a big part of the problem. You have higher ring leakage, more thermal expansion of gasses under the piston, and much higher pressure cycling due to engine rotation than a 400" engine. Bringing the case pressure down needs a big pump, more speed, or some combination of both.
For those with a clean sheet of paper: more pan volume is always better.
Boffin Emeritus
Page 3 of 3 1 2 3
