Re: Molly dropped center link
[Re: Stanton]
#2630274
03/08/19 10:25 AM
03/08/19 10:25 AM
Posts: 5,989 Anoka County, MN
Leigh
Anoka County, MN
MANY years ago Herb McCandless cut the ends off the center link and spaced them further from the bar to gain clearance. Thinking it through I suspect he used two center links to make one. In fact, if you welded the spaced bar to the center link first and then cut out the old section you wouldn't even have to worry about any alignment or hole spacing issues. This is the method we used to straighten the drag link, to get it through the Milodon pan. Didn't even have to reset the toe.
