Re: check engine light, low temp on gauge
[Re: a12rag]
#2639413
03/31/19 11:06 PM
03/31/19 11:06 PM
Posts: 857 Southeast Pa.
SALEM1912
Southeast Pa.
That light was required for emissions. Means to have your EGR serviced.Appoxmently every 50K. If I remember there is a switch behind the cluster to flip and reset. Shouldn't be causing any performance issues. You may need a 195* thermostat don't think the two are related.
