CPPA Headers and angle spark plugs #2628288
03/03/19 03:27 PM
03/03/19 03:27 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
I have a set of CPPA 2 inch headers with iron heads on my R/B block. I was looking at my #6 spark plug and it doesn’t look like I can use a set of angle plug head with these headers. Has anyone come across this problem?
Re: CPPA Headers and angle spark plugs [Re: Harley] #2628304
03/03/19 03:54 PM
03/03/19 03:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think you can put a small dent in that pipe like Hooker and the newer Pro Part headers have to accommodate the angle plug heads scope hammer wrench grin
Re: CPPA Headers and angle spark plugs [Re: Harley] #2628328
03/03/19 05:26 PM
03/03/19 05:26 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
are the 2" CPPA's the same as the TTI's? I have 2" TTI's and angle plugs are easier to maintain than when I was using straight plug iron heads.
Re: CPPA Headers and angle spark plugs [Re: lewtot184] #2628377
03/03/19 07:11 PM
03/03/19 07:11 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I have an older set of the 2" CPPA headers that I got in the mid 80's on a 440 block with EZ-1 heads. #6 tube had to be dinged a little and I used an angled plug boot, not the usual 90 degree boots, on that plug. So far it hasnt burned the plug boot after several years of running.
Re: CPPA Headers and angle spark plugs [Re: Harley] #2628416
03/03/19 08:56 PM
03/03/19 08:56 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
Thanks for the information. I got these headers new back in the 90's and they are in really good shape. I guess i am going to have to take a hammer to them and clearance them a bit. Thanks again
Re: CPPA Headers and angle spark plugs [Re: Harley] #2628476
03/03/19 11:20 PM
03/03/19 11:20 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought these 2" CPPA headers in 1996 and I did not dent any tubes as all the plugs are easy to do as long as the eng is not hot. We use RPM Eddy heads with the CPPA headers. Ron
Re: CPPA Headers and angle spark plugs [Re: Harley] #2628487
03/03/19 11:44 PM
03/03/19 11:44 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
The only plug that looks like i might have a problem with is the Number 6 cylinder. I hope i am wrong and it will clear, if not i have a few different hammers to make it work.
Now i have to figure out which head to go with.
My iron heads have been on three different motors and they have not been apart since the mid 90's and are leaking oil down the guide. I think it's about time and stepped up to a better head for my combo.
Thanks again.
Re: CPPA Headers and angle spark plugs [Re: Harley] #2628550
03/04/19 02:25 AM
03/04/19 02:25 AM
You might want to use a 3/8 drive impact spark plug socket for dimpling that header pipe hammer twocents
Re: CPPA Headers and angle spark plugs [Re: Cab_Burge] #2628592
03/04/19 10:30 AM
03/04/19 10:30 AM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
hammer
Re: CPPA Headers and angle spark plugs [Re: Harley] #2628607
03/04/19 11:18 AM
03/04/19 11:18 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
just did a head swap and no 6 fits better because the angle moves away from that tight tube.
JAKES AUTOMOTIVE
Re: CPPA Headers and angle spark plugs [Re: Harley] #2628714
03/04/19 03:32 PM
03/04/19 03:32 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
My problem isn't the number six tube, it's the number 2 tube that comes over the six tube and make a down turn and is right next to the six plug. Maybe i got a first run on these headers because i have yet to see a set like what i have. Just my luck, Lol
Re: CPPA Headers and angle spark plugs [Re: Harley] #2628993
03/05/19 02:51 AM
03/05/19 02:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am sorry as I just realized you said iron heads. I posted about the RPM heads on my boys Dart. But if you run the RPM or any aluminum head with angled plugs it gives more room with TTI and CPPA headers. And you will also be using the small 5/8 plugs. So if you go with the RPM or another angled plug aluminum head you should be fine. Good luck , Ron
Re: CPPA Headers and angle spark plugs [Re: 383man] #2629222
03/05/19 03:42 PM
03/05/19 03:42 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
2 in CPPAs on my 65 440.They are some of the first they made.6 is a real pain to get to.Even with iron heads they were a pain.same with the scatter shield and starter wires.I use taylor Spiro pros for 440 that are cut to length.Ran the last set for 15 years and never burnt one.New set is on at least 3 years now.Only reson i replace the old set was they were old and nasty looking.Rocky
Chrysler Firepower
Re: CPPA Headers and angle spark plugs [Re: therocks] #2629399
03/05/19 10:01 PM
03/05/19 10:01 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
Yes the Number six plug is a pita to get to and get the wire on as well. I have never burnt a plug wire either. My header look like they are new which surprises me after all the years and miles on them.
