Re: Electric Vacuum pump on 69 charger to run doors???
[Re: Moparnut426]
#2628925
03/04/19 11:56 PM
03/04/19 11:56 PM
moparpollack
Lil Herman
Lil Herman
85086
There are a lot of modern cars that run small vacuum pumps, might be worth checking out to find one.
[Re: Moparnut426]
#2628931
03/05/19 12:09 AM
03/05/19 12:09 AM
Posts: 18,157 Mass
DAYCLONA
Mass
So in theory I can use the headlight power side to trigger a relay to run the vacuum pump, but to shut it off is the tricky part.
Would it be easier to convert this to an electric motor set up, or to wire in a little vacuum pump? I think you need to go thru the vacuum system and bring it up to snuff if it's stock 50 year old components?, running a reserve canister?, factory style?.... Your running a 509 lift with 292 duration and having problems with sufficient vacuum? whats manifold vac at idle?, automatic transmission?, power brakes? My Daytona is running 520 lift with 284 duration, 6 pack, manual transmission and about 10-12 inches/vac at idle, dual diaphram Bendix booster w/4 wheel disc and I have plenty of vacuum to lift the Daytona doors which have to weight 2-3 times heavier than stock 68-70 Charger doors, and my light's vacuum system is basically the same component wise as yours...
[Re: DAYCLONA]
#2629211
03/05/19 03:30 PM
03/05/19 03:30 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Would it be easier to convert this to an electric motor set up, or to wire in a little vacuum pump? I think you need to go thru the vacuum system and bring it up to snuff if it's stock 50 year old components?, running a reserve canister?, factory style?.... Your running a 509 lift with 292 duration and having problems with sufficient vacuum? whats manifold vac at idle?, automatic transmission?, power brakes? My Daytona is running 520 lift with 284 duration, 6 pack, manual transmission and about 10-12 inches/vac at idle, dual diaphram Bendix booster w/4 wheel disc and I have plenty of vacuum to lift the Daytona doors which have to weight 2-3 times heavier than stock 68-70 Charger doors, and my light's vacuum system is basically the same component wise as yours... So Its a cast manifold basic stock rebuilt 70 440 sixpac engine and hemi 4 speed out of a70 challenger. I have installed FiTech efi six pac on it. isnt fired up just yet, still waiting on a few loose ends. 509 cam, and very stock everything else. Power brakes
