Aluminum Radiator / Fan Questions- 73 Dart Small Block
#2628687
03/04/19 02:45 PM
03/04/19 02:45 PM
Posts: 336 Creston, Iowa
340man4ever
Creston, Iowa
Finishing a mild street strip 73 Dart with a 360 small block. Looking for a drop in aluminum radiator that would have some room for growth for down the road when I can put a hotter motor in this thing. Current motor dynoed 375hp. What do you guys like for a radiator? I was planning on running a mechanical fan set up....Is that the thing to do or just go electric? Shroud? Thanks in advance
Curator at Adams County Speed Shop
Re: Aluminum Radiator / Fan Questions- 73 Dart Small Block
[Re: 340man4ever]
#2628717
03/04/19 03:40 PM
03/04/19 03:40 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Finding one to fit will be easier with the later A body. I would go aluminum for sure , cross flow is a plus , and which ever fan you use , a shroud is your friend. I had the Chevrolet SSR electric on mine and it worked well.......it has the shroud built in , but you have to be creative in mounting it. I am now adding to the mess on the front of the motor , so it is now too thick and I will be looking at other options.
[Re: tubtar]
#2628719
03/04/19 03:46 PM
03/04/19 03:46 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
Finding one to fit will be easier with the later A body. I would go aluminum for sure , cross flow is a plus , and which ever fan you use , a shroud is your friend. I had the Chevrolet SSR electric on mine and it worked well.......it has the shroud built in , but you have to be creative in mounting it. I am now adding to the mess on the front of the motor , so it is now too thick and I will be looking at other options. The Dodge Intrepid fan is a decent option. I have a Mezziere pump and it fits between the two fans(after a little hacking), they have a decent shroud built in but you have to get creative to cover the whole rad with it.
68 Barracuda Formula S 340
[Re: topside]
#2628757
03/04/19 04:57 PM
03/04/19 04:57 PM
340man4ever
Creston, Iowa
Thank you for the responses....much appreciated.
Additional info:
A 26" wide radiator is the direction I was hoping to go....
Car is a 904 auto with Dynamic Trans and 9.5 Converter....Planning on running a seperate transmission cooler from radiator ( a large B & M Supercooler)
[Re: Chip]
#2628780
03/04/19 05:38 PM
03/04/19 05:38 PM
340man4ever
Creston, Iowa
Car is a small block
Radiator will need inlet / outlet locations suitable for small block LA 360
[Re: 340man4ever]
#2628885
03/04/19 10:23 PM
03/04/19 10:23 PM
tubtar
St. Paul , Mn.
I am shopping for a radiator now.....there are a lot of direct fit options out there , none of which work for my deal. But minimal searching will turn up a lot of choices. I have my eye on a Griffin from Jegs , but I am not set on any one yet. Sorry.......I linked to the wrong one. Try this. http://www.speedcooling.com/26-Small-Block-Mopar-Radiator.html
