collapsible steering shaft #2628584
03/04/19 08:23 AM
03/04/19 08:23 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
I want to run a solid u-joint instead of the factory steering coupler. Problem is that a solid u-joint will transmit K-frame movement to the upper steering column bearing and possibly damage it. Therefore I need some sort of length flexibility comparable to the original coupler. If I were to break the plastic shear pins in the steering column this would solve the problem, wouldn't it? These shear pins serve two purposes: 1.) preventing the column from walking into the factory coupler and bottoming out and 2.) makes installation easier.
Once installed it doesn't matter if there are shear pins or not as the outer shaft is held by the upper bearing and the inner shaft is held by the solid u-joint - the shaft can't go anywhere.
Ok, here's my question: how tightly does the inner shaft fit into the outer shaft? Would broken shear pins allow rattling or some sort of play (when twisting inner and outer shaft)?
Re: collapsible steering shaft [Re: DGS] #2628586
03/04/19 09:07 AM
03/04/19 09:07 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The column will rattle. Mine has been collapsed and I hate the cheap sound.
Re: collapsible steering shaft [Re: DGS] #2628597
03/04/19 10:48 AM
03/04/19 10:48 AM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
The shear pins have been broken in my 70 E body for probably 40 years. I've not noticed any looseness or rattle noises. twocents
Re: collapsible steering shaft [Re: DGS] #2628933
03/05/19 12:12 AM
03/05/19 12:12 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The plastic the pins are part of sits in a grove cut into either the inner shaft, or the outer shaft (depending on the year of the column). As long as that plastic hasn't melted out, or been removed, the column shouldn't rattle. Over time, there may disintegration of the plastic if the pins have been broken off for a long time and that could cause a rattle. Gene
