Upper Ball Joints
#2626360
02/26/19 03:49 PM
02/26/19 03:49 PM
Posts: 1,534 Florida
CHRGR69
89 Dakota 2WD 3.9. I had local mechanic with a good rep change my upper bushings and ball joints. Turns out he "pressed" the ball joints instead of screwing them in and out. Now they move slightly. The truck was aligned and I don't want to remove the arms again. I'm thinking spot weld (never changing them again) or is there a nut I can screw on from the bottom side of the ball joint to tighten to the arm? And that's why I try to do repairs myself. That takes care of his rep!
Grandma always said I had "hands of gold"!
Re: Upper Ball Joints
[Re: a12rag]
#2626444
02/26/19 08:01 PM
02/26/19 08:01 PM
CHRGR69
MIG or ARC?
