Swapping steering shaft #2626394
02/26/19 05:15 PM
02/26/19 05:15 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I am going to change my 67 GTX from manual to power steering. I have bought a complete power steering column but would like to swap only the steering shaft and coupler and not the entire column. I have only taken apart one steering column ever and it was years ago so I don't remember exactly how it came apart. So my question is, in order to pull the manual shaft out and install the power shaft, do I have to take the entire column out of the car or can I do the swap with the column in the car?
Re: Swapping steering shaft [Re: 440mopar] #2626401
02/26/19 05:34 PM
02/26/19 05:34 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Gotta pull the column.
68 Charger R/T 440 auto
Re: Swapping steering shaft [Re: 440mopar] #2626406
02/26/19 05:54 PM
02/26/19 05:54 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The steering shaft slides into the column from the bottom. I don't see a way to do that if it's in the car.
Re: Swapping steering shaft [Re: 440mopar] #2626433
02/26/19 07:09 PM
02/26/19 07:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It may work if the K-frame is out.......
Easier to pull the column though.
Re: Swapping steering shaft [Re: 440mopar] #2626464
02/26/19 08:42 PM
02/26/19 08:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I've done it without pulling the column out. the column would have to be unbolted and pulled and tilted down. shaft would need to be knock out of the bearing and pushed to the front of the engine bay. it's really easier to just remove the steering wheel, drive the pin out of the coupler, unbolt the column, take it out and put it on a bench. the only reason I didn't pull the column on the change I did was a 1965 cable column.
Re: Swapping steering shaft [Re: 440mopar] #2626492
02/26/19 09:27 PM
02/26/19 09:27 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Lazy is the word. Pull the column and when you take it apart keep track of all the individual ball bearings from the lower bearing, they will go all directions.
