Fender Tag Code GTD #2626179
02/26/19 02:12 AM
02/26/19 02:12 AM
Detroit, Mi
michiganhotrod1 Offline OP
Detroit, Mi
I just brought home a find, a 71 Cuda 340 convertible.
I decoded the fender tag. All is checking out, except for the code in the top right, GTD. It does not come up on any of the lists I can find.
Any ideas what this is?
Mark
Re: Fender Tag Code GTD [Re: michiganhotrod1] #2626188
02/26/19 02:24 AM
02/26/19 02:24 AM
Detroit, Mi
Detroit, Mi
I would post a photo but I don't understand the instructions for this. M
Re: Fender Tag Code GTD [Re: michiganhotrod1] #2626191
02/26/19 02:40 AM
02/26/19 02:40 AM
Alabama
BigMoneyLewis Offline
Alabama
That's a typo, it should be CTD which means continued on another tag, in other words , it's a two tag car.
Greg
gregward@mchsi.com phone 256-852-0955
Re: Fender Tag Code GTD [Re: michiganhotrod1] #2626204
02/26/19 04:22 AM
02/26/19 04:22 AM
Detroit, Mi
Detroit, Mi
Thank you! Correct, you can see where a second tag may have been. This Is a bit of a "check off al the option boxes" car. Mark
Re: Fender Tag Code GTD [Re: michiganhotrod1] #2626447
02/26/19 08:07 PM
02/26/19 08:07 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Wow,what a great find.What's the story?
Re: Fender Tag Code GTD [Re: michiganhotrod1] #2626581
02/27/19 01:21 AM
02/27/19 01:21 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Should be a second tag maybe ask the person you bought it from if they have it or ask if the seller knows the owner before him. It should have the serial number and a few codes on it, 26 for the rad and other stuff. Car has some nice options. AC is nice in the summer during the day with the top up. Look around for a broad cast sheet, like behind the rear seat top, under the drivers seat or behind the top part of the drivers seat, tapped to the top of the heater box. They are the common places to start looking for a broad cast sheet.
Re: Fender Tag Code GTD [Re: michiganhotrod1] #2626622
02/27/19 03:52 AM
02/27/19 03:52 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
CTD - means continued on to a second tag. You are missing your second tag that would have listed your stripe option
Re: Fender Tag Code GTD [Re: michiganhotrod1] #2626869
02/27/19 09:33 PM
02/27/19 09:33 PM
Detroit, Mi
Detroit, Mi
I bought the car from a long time owner (early 1980's) in failing health. He was doing a few upgrades like Viper brakes but could not work on it any longer. I know where the car was sold new in Virginia, and much other history, and have all of the replaced components.
I need to finish the work and get it back on the road ... after I recover from rotator cuff surgery!
Re: Fender Tag Code GTD [Re: michiganhotrod1] #2629781
03/06/19 09:36 PM
03/06/19 09:36 PM
MAIne
MoparABE Offline
MoparABE  Offline
MAIne
cool car , any luck on the 2nd tag?
Re: Fender Tag Code GTD [Re: MoparABE] #2632309
03/13/19 02:34 PM
03/13/19 02:34 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
If it is a billboard car (V6X) that would be on the second tag as well.
1970 Dodge Challenger T/A
