Teflon ape on fuel line fittings #2625180
02/23/19 06:45 PM
02/23/19 06:45 PM
robertop Offline OP
robertop  Offline OP
I might be just full of bull, but I seem to remember reading somewhere that you don't use teflon tape on fuel line fittings, and the reason escapes me. Do you think this is only rubbish?
Re: Teflon ape on fuel line fittings [Re: robertop] #2625182
02/23/19 06:48 PM
02/23/19 06:48 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I would never use teflon tape on fuel fittings. If it breaks off (including during removal) it can plug up small orifices in the fuel system including the carb.
A good sealant (I use Loctite PST teflon sealant) is recommended.
Re: Teflon ape on fuel line fittings [Re: robertop] #2625211
02/23/19 08:21 PM
02/23/19 08:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The first thing one should do is establish what type of fitting you are referring to. Inverted flare as well as AN flared type fittings require no sealant.
The only fitting that does is pipe type thread which is a tapered thread. There are several different acceptable sealants that can be used. The primary concern with the tape is it sometimes leaves strands behind that can find there way to the fuel system/ carburetor
twocents beer
Re: Teflon ape on fuel line fittings [Re: robertop] #2625220
02/23/19 08:48 PM
02/23/19 08:48 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use liquid Teflon sealer on all my pipe thread fittings. Just a dab on the clean dry threads and you will be leak free. You can get it from any parts store or even the hardware stores carry it.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Teflon ape on fuel line fittings [Re: fourgearsavoy] #2625222
02/23/19 09:00 PM
02/23/19 09:00 PM
KY USA
mopargem Online tonguue
mopargem  Online Tonguue
KY USA
If you were to use teflon tape, it needs to be the yellow type which is resistant to fuel
Re: Teflon ape on fuel line fittings [Re: mopargem] #2625237
02/23/19 09:49 PM
02/23/19 09:49 PM
Kirkland, Washington
Pacnorthcuda Offline
Yellow Teflon tape is designed for natural gas and propane lines, not gasoline.
Re: Teflon ape on fuel line fittings [Re: Pacnorthcuda] #2625248
02/23/19 10:05 PM
02/23/19 10:05 PM
iagree
White for liquid gasoline or diesel scope
OP, do NOT use any sealant on any AN fitting other than the NPT ends twocents
Re: Teflon ape on fuel line fittings [Re: Pacnorthcuda] #2625274
02/24/19 12:08 AM
02/24/19 12:08 AM
KY USA
KY USA
Oh no my bad sry. I’ve beem wrong all these years
Re: Teflon ape on fuel line fittings [Re: mopargem] #2625317
02/24/19 03:29 AM
02/24/19 03:29 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Good thing you never had a 'splosion!
Re: Teflon ape on fuel line fittings [Re: Sunroofcuda] #2625524
02/24/19 04:57 PM
02/24/19 04:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Per the following there really isn't a "CLEAN" answer regarding the use of the yellow tape. Seems there are different types depending on the usage. NICE!!!! beer
YELLOW TEFLON TAPE ARTICLE
Re: Teflon ape on fuel line fittings [Re: robertop] #2625536
02/24/19 05:27 PM
02/24/19 05:27 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
GM used white Teflon tape for years on Q-Jet fuel inlets, not as a sealant, but as a friction reducer, it allowed the flare nut to be tightened sufficiently without rounding the flats. Paul
Re: Teflon ape on fuel line fittings [Re: iapco103] #2625600
02/24/19 08:39 PM
02/24/19 08:39 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
For flare fittings, I always used a little grease on the back of the tube flare, and on the nut flare and threads.
Re: Teflon ape on fuel line fittings [Re: BSB67] #2625845
02/25/19 02:06 PM
02/25/19 02:06 PM
moparx Offline
moparx  Offline
anti seize is my preferred stuff to use.
beer
Re: Teflon ape on fuel line fittings [Re: iapco103] #2625910
02/25/19 04:14 PM
02/25/19 04:14 PM
If GM had flared the fuel line carb end properly they wouldn't have needed to do that work
Re: Teflon ape on fuel line fittings [Re: Cab_Burge] #2626068
02/25/19 09:30 PM
02/25/19 09:30 PM
okla.
sam64 Offline
sam64  Offline
okla.
white Teflon turns clear in gas and when a little piece gits in a needle and seat you can't see it and will cause you to cuss a lot while trying to figure out why it still floods.
Re: Teflon ape on fuel line fittings [Re: Cab_Burge] #2626087
02/25/19 10:31 PM
02/25/19 10:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree I wasn't going to start the debate but seriously doubt they used the tape twocents beer
Re: Teflon ape on fuel line fittings [Re: robertop] #2626119
02/25/19 11:53 PM
02/25/19 11:53 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I've been using the yellow on fuel (gasoline) fittings for many years, including adding to an AN fitting that leaked a bit.
It may not have been made for gasoline but I've never an issue with it failing yet.
My roll of yellow is so old there's no label on it anymore, but it was whatever was at Home Depot at the time.
Re: Teflon ape on fuel line fittings [Re: robertop] #2626187
02/26/19 02:24 AM
02/26/19 02:24 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I remember a cartoon called the GRAPE Ape but Teflon Ape is one I've never heard of.
Re: Teflon ape on fuel line fittings [Re: Kern Dog] #2626241
02/26/19 11:11 AM
02/26/19 11:11 AM
robertop Offline OP
robertop  Offline OP
Oh, it's a similar character, only a very slippery one! So I forgot to check the title, but remember nobody likes a wise guy.....just joking, I deserve that.
Re: Teflon ape on fuel line fittings [Re: Kern Dog] #2626316
02/26/19 02:42 PM
02/26/19 02:42 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
FYI, The Teflon APE is the one that gets loose in your fuel system or starts a fire under the hood grin beer
