'69 Fury 383/ 727 w/2.76 Diff. 275/60-15" rubber.
Using Randy's ring & pinion calculator I get a RPM of 1870 @ 55mph.
http://www.ringpinion.com/Calc_RPM.aspxI just put a tach on today and went for a ride. It reads 2250 @ 55. Checked the RPMs with my tach/dwell meter and my multi function timeng light with digital RPM readout. Seems accurate. Does the stock converter slip that much? If so, which converter would you replace it with?
Oh- I'll be putting in a 451 soon, so please keep that in mind.
I'm keeping the 2.76 gears and will freshen the 727.
451 is being built for torque and highway cruising.
https://board.moparts.org/ubbthreads/show...e=0#Post5071931
