Re: What would cause my starter to break?
[Re: HealthServices]
#262373
03/22/09 09:21 PM
03/22/09 09:21 PM
Posts: 13,613 md
mopars4ever
md
[Re: mopars4ever]
#262375
03/22/09 09:32 PM
03/22/09 09:32 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I thought they were all made in china Just don't want the new one to break too. I found his post. Funny how quickly the threads get pushed back.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: autoxcuda]
#262379
03/22/09 10:18 PM
03/22/09 10:18 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
Was it a rebuilt one or a new one? How long had it been installed?
Did it rub up against the block? Wasn't there some deal about mini starters and big blocks. Lie you had to grind the block for clearance or get a certain mini starter?
Thats a good point. If there was ANY contact with the block the starter bolts could have induced tremendous pressure on the snout as it was tightened down.
[Re: autoxcuda]
#262381
03/22/09 10:31 PM
03/22/09 10:31 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I have these wonderful Hedman 2-1/8 headers that touched the starter. So when I replaced it this last time I dented the header so they would not touch. and wrapped the tube with heatwrap. Last long Mini touch but did not break. This short mini did not touch but broke. I just put a RobbMC starter in today.
Allen
#262382
03/22/09 10:45 PM
03/22/09 10:45 PM
Posts: 13,613 md
mopars4ever
md
Nope, just the cheap junk ones
[Re: mopars4ever]
#262383
03/22/09 10:52 PM
03/22/09 10:52 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Well the RobbMC starter looks pretty nice. I forgot but I think they use the Hitachi motor vs. the Nippondenso. Hopefully I won't have this problem again they certainly don't look like they will get heat soaked. The big plus is they can be clocked into any position as long as it does not hit something.
Allen
#262385
03/23/09 11:31 AM
03/23/09 11:31 AM
Posts: 961 Carson City, Nevada
RobbMc
Carson City, Nevada
Thanks HS. We use US designed Remy (f.k.a. Delco Remy) motors and solenoids. Everything forward of the motor is our own design.
You should have a lot more header clearance with our starter. Not only can you rotate the solenoid to any position, but our motor is directly behind the pinion gear on the starter (rather than offset to one side). This puts the motor closer to the block, approximately where the solenoid is on your old Denso style starter.
