Welding “stainless” mufflers in exhaust system
#2623585
02/20/19 03:00 AM
02/20/19 03:00 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I have been custom building exhaust systems for the past 12 years or so for myself. I have done a bunch of them and my personal preference is to completely weld the system together , with the exception of the axle connection, if it has tailpipes and i may need to remove it for repairs. I have welded flowmasters and dynomax ultraflows with no problems at all. I use mig with er70s(if i remember correctly) and the dynomax are stainless 304. No problems miging to steel pipes after 10 years of driving/ racing. Now to my question: i’m building another system for my 73 b body, and im trying the magnaflows , which i read are stainless. But, they dont state what grade stainless. Anyone welded these to steel ex pipes with er70s mig?
Thanks.
Re: Welding “stainless” mufflers in exhaust system
[Re: Chargerfan68]
#2623675
02/20/19 01:20 PM
02/20/19 01:20 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Why are you using a 70 filler? Seems to me you are offering a nice exhaust solution that I like, but you are adding a rust band everywhere you close a connection.
[Re: Chargerfan68]
#2623772
02/20/19 04:24 PM
02/20/19 04:24 PM
Chargerfan68
New York, USA
Thanks for the replies. I use that filler because i usually work with mild steel and the rest of the exhaust is steel pipes. What do you recommend for filler when welding steel pipes to stainless mufflers?
[Re: Chargerfan68]
#2623786
02/20/19 05:09 PM
02/20/19 05:09 PM
jcc
Bitopia
Maybe I misread your application, I was thinking you were welding ss to ss, if steel to ss, then my rust/cosmetic concerns are in consequential. I am not sure the filer alloy is that important ss to steel, as the weld will re alloy itself during the weld, and in most applications, this is not a high stress weld, but corrosion and long term thermal fatigue are more concerns. I recently did my Class 8 Semi out of SS 5" tubing, got tired of the a run Alum coated steel rusting thru. Tig is my method, with back purge, not sure what would be best for mig.
[Re: Chargerfan68]
#2623791
02/20/19 05:18 PM
02/20/19 05:18 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Find a way to use clamps on the stainless muffs
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Chargerfan68]
#2624076
02/21/19 03:32 AM
02/21/19 03:32 AM
Chargerfan68
New York, USA
I did a little more digging around and learned that 409 ss will be magnetic and 304 ss will not. Even though i read that the Magnaflow muffler is 304, a magnet did stick to it. All surfaces including the pipe extending out were magnetic, so that leads me to believe it is 409 ss. In that case i will just mig it as usual like i do with the dynomax ultraflo welded muffs that are 409. Never had a problem nor fatigue/ corrosion issues at all. Thanks for the feedback.
