Welding “stainless” mufflers in exhaust system
#2623585
02/20/19 03:00 AM
02/20/19 03:00 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I have been custom building exhaust systems for the past 12 years or so for myself. I have done a bunch of them and my personal preference is to completely weld the system together , with the exception of the axle connection, if it has tailpipes and i may need to remove it for repairs. I have welded flowmasters and dynomax ultraflows with no problems at all. I use mig with er70s(if i remember correctly) and the dynomax are stainless 304. No problems miging to steel pipes after 10 years of driving/ racing. Now to my question: i’m building another system for my 73 b body, and im trying the magnaflows , which i read are stainless. But, they dont state what grade stainless. Anyone welded these to steel ex pipes with er70s mig?
Thanks.
Re: Welding “stainless” mufflers in exhaust system
[Re: Chargerfan68]
#2623675
02/20/19 01:20 PM
02/20/19 01:20 PM
Posts: 22,722 Bitopia
jcc
Bitopia
Why are you using a 70 filler? Seems to me you are offering a nice exhaust solution that I like, but you are adding a rust band everywhere you close a connection.
[Re: Chargerfan68]
#2623772
02/20/19 04:24 PM
02/20/19 04:24 PM
Chargerfan68
New York, USA
Thanks for the replies. I use that filler because i usually work with mild steel and the rest of the exhaust is steel pipes. What do you recommend for filler when welding steel pipes to stainless mufflers?
[Re: Chargerfan68]
#2623786
02/20/19 05:09 PM
02/20/19 05:09 PM
jcc
Bitopia
Maybe I misread your application, I was thinking you were welding ss to ss, if steel to ss, then my rust/cosmetic concerns are in consequential. I am not sure the filer alloy is that important ss to steel, as the weld will re alloy itself during the weld, and in most applications, this is not a high stress weld, but corrosion and long term thermal fatigue are more concerns. I recently did my Class 8 Semi out of SS 5" tubing, got tired of the a run Alum coated steel rusting thru. Tig is my method, with back purge, not sure what would be best for mig.
[Re: Chargerfan68]
#2623791
02/20/19 05:18 PM
02/20/19 05:18 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Find a way to use clamps on the stainless muffs
[Re: Chargerfan68]
#2624076
02/21/19 03:32 AM
02/21/19 03:32 AM
Chargerfan68
New York, USA
I did a little more digging around and learned that 409 ss will be magnetic and 304 ss will not. Even though i read that the Magnaflow muffler is 304, a magnet did stick to it. All surfaces including the pipe extending out were magnetic, so that leads me to believe it is 409 ss. In that case i will just mig it as usual like i do with the dynomax ultraflo welded muffs that are 409. Never had a problem nor fatigue/ corrosion issues at all. Thanks for the feedback.
