Re: How to get code off this fender tag ? [Re: ScottSmith_Harms] #2623510
02/19/19 11:44 PM
02/19/19 11:44 PM
Near Columbus, Ohio
++MAX WEDGE++ Offline OP
Near Columbus, Ohio
Originally Posted By ScottSmith_Harms
If you decide to soak it to remove the rust I'd recommend Evaporust not acid (vinegar). Also, Dan's tag decipher may be more accurate concerning the L25 vs M25. Does your car have a trunk light? Rocker moldings?
Yes car has trunk lite. It does not have on it (currently) rocker moldings but that not to say they weren't there, I would have to check and see if there is clips there that might have held them on at one time.
Is there a big difference between L25 and M25?
Re: How to get code off this fender tag ? [Re: cdwmotorsports] #2623515
02/19/19 11:53 PM
02/19/19 11:53 PM
Near Columbus, Ohio
Near Columbus, Ohio
Originally Posted By cdwmotorsports
If ever there was a car that needed a new fender tag made.
What’s the rest of the car look like?
Believe it or not it has a super solid frame and trunk.....crazy I know laugh
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623527
02/20/19 12:23 AM
02/20/19 12:23 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
L25 is the code for the trunk light option (which your picture shows it has) so my guess at the M25 is most likely incorrect, Dan's L25 code makes the most sense as I don't see any signs of moldings on your car.
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623545
02/20/19 01:05 AM
02/20/19 01:05 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
That car looks way better than what I thought it would based on that tag. I would’ve bought it.
eBay-cdwmotorsports
Re: How to get code off this fender tag ? [Re: cdwmotorsports] #2623594
02/20/19 03:50 AM
02/20/19 03:50 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
….. it's just Microsoft "PAINT"
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623631
02/20/19 11:29 AM
02/20/19 11:29 AM
Near Columbus, Ohio
Near Columbus, Ohio
Dan,
YOU are THE MAN !!!!!
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623691
02/20/19 02:01 PM
02/20/19 02:01 PM
Martinsville, IN
Martinsville, IN
Interesting Dan
eBay-cdwmotorsports
Re: How to get code off this fender tag ? [Re: ScottSmith_Harms] #2623856
02/20/19 06:45 PM
02/20/19 06:45 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Probably not 100% accurate but with some interpretive guesswork this should be pretty close.
VL29: Plymouth Duster - Base/low level model
G = 318 V8
2 = 1972 model year
H = Plant = Hamtramck, MI, USA
Scott, since we're trying to help him decipher his codes properly, I need to correct you. As you know, "H" would be the 340 engine code. "B" as the 7th digit would be the plant code for Hamtramck, not "H".
beer
Re: How to get code off this fender tag ? [Re: 318 Stroker] #2623866
02/20/19 07:08 PM
02/20/19 07:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Absalutely, brain fart on my part. smile I was typing that fat fingered on my cell phone and made a few changes, scrambled it somehow. I fixed it.
Re: How to get code off this fender tag ? [Re: ScottSmith_Harms] #2623899
02/20/19 08:29 PM
02/20/19 08:29 PM
Near Columbus, Ohio
Near Columbus, Ohio
Any thoughts on production numbers with the "Twister Package" and What is a "Twister Package" ????
Thanks Scott
