Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2622437
02/17/19 02:29 AM
02/17/19 02:29 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Please tell me you don't use that air filter on it.
14 X 4 " should be minimum.
I'd even look at a 6" tall element if you have to run a filter.
Re: Dragula's Quest for the 5's....on Pump Gas [Re: BradH] #2622609
02/17/19 05:36 PM
02/17/19 05:36 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Originally Posted By BradH
Originally Posted By Dragula
And so the upgrades are starting to come together...Heads will stay the same for now...My next build is hopefully a procharger motor...
You're leaving a significant amount of power on the table by not spending any money on the heads. I guess I don't understand what your goal is, since it seems to have changed from the original post.
5's is still the goal ....We weren't far off last year, and with a burnt head gasket and blown header tube, there should be some power left on the table. But yes, heads were what we originally wanted to do, but I think we will change it up more next year and with a procharger, we don't need super good heads.
Money was the other decision. New heads were outside the budget, and the porting quotes I got seemed pretty high to me. So we went with new pistons and head gaskets to get a little closer to max compression. We will be starting the season on 50/50 race fuel and getting everything dialed in from there.
Re: Dragula's Quest for the 5's....on Pump Gas [Re: tubtar] #2622614
02/17/19 05:42 PM
02/17/19 05:42 PM
Dragula Offline OP
Dragula  Offline OP
Were I am pitted its like a sandbox and I have fenderwell headers that kick all that stuff up. I originally bought that to fit the Hemi, but I will have cut the intake down or switch intakes for it to fit the hemi. So, I have not raced the Duster with an air cleaner, but I am changing the hood this year to a forward facing scoop, and that might fit right in the scoop. I am worried about getting crap in there....
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2622722
02/17/19 10:43 PM
02/17/19 10:43 PM
you definitely need to run a air cleaner, there is power in straightening out the airflow up devil trust me on this, testing on the engine dyno and again at the track has shown me as well as many others about this scope
Drop base air cleaners are the answer to carb. to hood problems scope up 16x3 inch elements works very well on 512 + C.I. motors with excess of 750 HP thumbs
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2622854
02/18/19 11:24 AM
02/18/19 11:24 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I didn't see it if you said it had to be na. I'd put a plate kit on it as is and presto. Pump gas works pretty good with spray to a point. Also the cheapest option.
More compression would help too, at least at the track where the motor will be working in higher rpms. The cheapo 93 pump with 10 percent ethanol works better than straight gas high test
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2622868
02/18/19 12:15 PM
02/18/19 12:15 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'm curious about the prices you were quoted for porting your heads, what the quotes included, and why you think they were "pretty high".
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2622999
02/18/19 05:55 PM
02/18/19 05:55 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
But if you go to a 50/50 mix it won't be a pump gas combo anymore. All those years of insisting on being pump gas and you probably could have ran a 5 five years ago if you weren't so stubborn. LOL. But then again aren't we all Stubborn in our own ways. I know I am.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dragula's Quest for the 5's....on Pump Gas [Re: pittsburghracer] #2623091
02/18/19 10:42 PM
02/18/19 10:42 PM
Dragula Offline OP
Dragula  Offline OP
Well stubborn, and cheap at times....At least I got rid of the purple cam...
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2631239
03/10/19 09:42 PM
03/10/19 09:42 PM
Dragula Offline OP
Dragula  Offline OP
New valve train solved a lot of my push rod issues....So hopefully we will have a much better race season. The rockers I had were ok on a 440 block, but on a 400, the push rods were rubbing. Also switched to a Flow cooler mechanical water pump over the Mopar one, a new Milidon oil pump, and a few other small things...
Now with new Comp Cams rockers, and Manton push rods, life is good again. Ready for race season.... Had to lathe some material off all the spacers and the top hold downs to fit, but once I clearanced all of them, it went together perfectly. Car goes for paint work next..
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2631335
03/11/19 08:25 AM
03/11/19 08:25 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
WHY are you still running a mechanical water pump? With an ET goal in mind, that ought to be the first thing to go.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2631371
03/11/19 10:37 AM
03/11/19 10:37 AM
moparx Offline
moparx  Offline
what was the difference between the flowcooler and mopar water pump ?
beer
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2631400
03/11/19 11:44 AM
03/11/19 11:44 AM
Nevada
merpar Offline
merpar  Offline
Nevada
Those comp cams rockers, are they bushed? If not I would not run them. Steel on steel will gaul with roller cam spring pressures. Without thinking I ran a set years ago, comp cams. only .625 lift. Got one pass and several of the rockers were gauled. You might want to think about it!
Re: Dragula's Quest for the 5's....on Pump Gas [Re: moparx] #2631404
03/11/19 11:49 AM
03/11/19 11:49 AM
beer
Flo-Kooler pumps have the anti cavitation plate on the impeller and move more water. I ran one for a while, nice piece.
CHIP
Re: Dragula's Quest for the 5's....on Pump Gas [Re: an8sec70cuda] #2631466
03/11/19 03:01 PM
03/11/19 03:01 PM
gregsdart Offline
gregsdart  Offline
Porting your heads will probably get you to your goal. You can try tightening the lash also, that might be worth something if the cam duration is less than 280 @ .050. Any place to scrub a pound or two off? Every pound is worth about .001 ET.
Re: Dragula's Quest for the 5's....on Pump Gas [Re: merpar] #2631509
03/11/19 05:46 PM
03/11/19 05:46 PM
Dragula Offline OP
Dragula  Offline OP
Cause it fits, and when I upgrade the electric 35gpm one on the Hemi this year with a 55gpm pump, I will have one...I can put on there. I am sure I will have to make all special spacers to make it all fit though. Winter has been too cold to do it now.
Rockers are bushed....I like them a lot so far. Wouldn't use them if they weren't bushed.
We will be looking in to it next year. Heads are fresh and ready to go.....Prices for porting were pretty high I thought, only so much money to go around.....
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2631595
03/11/19 09:02 PM
03/11/19 09:02 PM
gregsdart Offline
gregsdart  Offline
I understand on the money thing. The mrs just bought furniture, so my budget is shot!
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2631707
03/12/19 08:18 AM
03/12/19 08:18 AM
Use a "drop-in" style pump that fits in the factory housing, then all you'll need is a short belt.
CHIP
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2631872
03/12/19 12:50 PM
03/12/19 12:50 PM
My old pump gas Duster ran 10.69 ET at 124. MPH with the original set of ported big valve 906 heads, swapping the heads to a set of MCH CNC ported Eddy RPM heads picked it up to 10.40s at 127.MPH. I ended up swapping out the 4.250 stroke crank to a 4.300 to raise the compression ratio from 9.25 to 1 to 10.3 to 1 and that help it run in the 10.30s, the final change to that motor was changing the heads again to a set of Indy SR M.W. ports with a single Indy 400-3 with Holley 1050 CFM Dominator. The heads where 9.0 CC smaller than the Eddy RPM so that raised the compression ratio up to 10.8 to 1.
Those changes ended up with a best of 9.993 at 134.8 MPH with the air cleaner and full exhaust system on and hooked upboogie
Re: Dragula's Quest for the 5's....on Pump Gas [Re: Dragula] #2631947
03/12/19 03:41 PM
03/12/19 03:41 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
one more point of compression and a nice solid roller.....
Re: Dragula's Quest for the 5's....on Pump Gas [Re: cuda499] #2664611
06/10/19 11:47 PM
06/10/19 11:47 PM
Dragula Offline OP
Dragula  Offline OP
Well first two outings and car is working and running great....I have not hit my goal of running 5's, but I have not had to pull the valve covers even once...That means the new valve train is holding up really well.
So far fastest pass is a 6.13...No where near 5.99 I want, but its a work in progress. Was hoping for a little quicker out of the gate, but it will get faster. 60ft is now down to a 1.34 consistently.
Things I have learned is the new combo likes more rear tire pressure and more fuel. So I am homing in on both right now. Still tinkering with the timing and carb fuel pressure too....
And its not currently on pump gas, but in the future, I will be going back to 93, but with water/meth injection....So right now I am running C12/108 and when I get back to work somewhere, I will spring for the Snow kit...
And here is a more up to date picture...
6.17 Pass
https://www.youtube.com/watch?v=nfyZYITsKNA&t=22s
6.18 Pass 1st round loss -.038 red
https://www.youtube.com/watch?v=WZAorsZxu0Q
