wheel and tire combo #2622841
02/18/19 09:20 AM
02/18/19 09:20 AM
indy
70moparmike Offline OP
indy
i have a 69 gtx hotchkis tvs kit. looking ti put 17 front and possible 18 rear? anyone running this on there's? what size rim , backspace and depth could you fit front and back? pics if any, don't want to have to test fit ten combo's to see if they fit, if anyone has already gone through it. thanks moparts
Re: wheel and tire combo [Re: 70moparmike] #2623195
02/19/19 02:39 AM
02/19/19 02:39 AM
Connecticut, USA
MRGTX Offline
MRGTX  Offline
Connecticut, USA
You’ll need to check up on backspace offsets but this car is a good starting point, IMO...as of 5 years ago, this is what he was running...
“MB Motoring 18×9.5 with sticky Falken Azenis RT 615K 275/35/18 tires went onto all four corners”
https://www.hotrod.com/articles/1970-plymouth-satellite-the-cab-ride/
Re: wheel and tire combo [Re: 70moparmike] #2623290
02/19/19 01:23 PM
02/19/19 01:23 PM
indy
indy
that's a 70? i know the dodges had more room on the rear then plymouth's? wondering if same from 69 to 70?
Re: wheel and tire combo [Re: 70moparmike] #2624224
02/21/19 03:07 PM
02/21/19 03:07 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
AlexP here has put similar rims tires on his 68-70? Road Runner.
Edit... 68 road runner... same tire fit:
Some details here:
https://board.moparts.org/ubbthreads/ubbt...tml#Post2623199
Re: wheel and tire combo [Re: autoxcuda] #2624495
02/21/19 11:49 PM
02/21/19 11:49 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
They work, but I want to get away from adapters and into a proper wheel.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
