Page 5 of 7 1 2 3 4 5 6 7
Re: Small Block vs Big Block [Re: WHITEDART] #2621694
02/15/19 02:54 PM
02/15/19 02:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Not many 1100Hp 400" Big blocks out there. Quite a few 1100hp small blocks out there, just saying. Also FWIW other makes have SB stuff that is a wider bore space they can work with as well.
Re: Small Block vs Big Block [Re: Al_Alguire] #2621698
02/15/19 03:08 PM
02/15/19 03:08 PM
Washington
madscientist Offline
Washington
Yep. Just like everything else Chrysler, you're screwed. The bigger bore spacing GM spaced stuff will beat all comers.
Are you saying 1100 HP NA stuff using Chrysler architecture? Pretty impressive.
Re: Small Block vs Big Block [Re: madscientist] #2621915
02/15/19 11:33 PM
02/15/19 11:33 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
. In Australian Pro Stock the small block Dodge has been at the top.. Bob book has built some pretty impressive ones as well.. there is room in a certain aftermarket block to do a 4 500 inch bore space. Sbm.... and a set of W8 could be manipulated
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Small Block vs Big Block [Re: WHITEDART] #2621933
02/15/19 11:58 PM
02/15/19 11:58 PM
Washington
Washington
. In Australian Pro Stock the small block Dodge has been at the top.. Bob book has built some pretty impressive ones as well.. there is room in a certain aftermarket block to do a 4 500 inch bore space. Sbm.... can a set of W8 could be manipulated
I forgot about the down under guys.
Re: Small Block vs Big Block [Re: madscientist] #2621957
02/16/19 12:39 AM
02/16/19 12:39 AM
bean town ....Ca
W
W
bean town ....Ca
. Did Chrysler do 4.500 bore space in NASCAR.
I want to say it was around the time Sterling Martin was driving the Coors car I thought I read something along those lines. I think it was quickly band if my memory serves me correctly which it rarely does
Re: Small Block vs Big Block [Re: WHITEDART] #2621977
02/16/19 01:55 AM
02/16/19 01:55 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Not many guys have the budget to build some of these engines a few of you are using for examples. High dollar high maintenance stuff for a few races a year
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block vs Big Block [Re: WHITEDART] #2622038
02/16/19 10:03 AM
02/16/19 10:03 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
r6 block is 4.5 BC I'm doing one now, R6P8
Erin Elliot , has gone 1200 with the R5P7 Larry Wallace has had some good luck, And Patterson racing
You can take the R5 to 4.250" bore, the steam holes keep you from going any larger….but would you dare…….. best bet is to stop at 4.20/4.22,
4.185X3.75(413CI) Great combo ...for any one who wants to spend the coin.... it will equal any power out put of the same CI RO7/X or SB2
R5 can take a 3.75 stroke and still have cylinder wall length to support a typical piston skirt , a 4.000" stroke will fit, issue there is rod ratio and urber short hockey puck piston……. And it makes for a short lived “race engine”
R5 block and P7 heads With 4.310" Nikosil liners and boring the mains to 2.500", to give you some more crank overlap a 467CI is possible and has been done and will make enough power to turn a top fuel Blower at 8k and have a few 100 to spare.
With out a doubt the larger the bore the better with a wedge, canted valve and Hemis, don't seam to care as much, less chance of shrouding the valve...one thing we all can agree on is the larger the Intake valve the better.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Small Block vs Big Block [Re: WHITEDART] #2622062
02/16/19 12:01 PM
02/16/19 12:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
When you change the bore pitch, you shorten the list of inherited characteristics. Like valve size and position, chamber shape, port config.
Oh wait - it's everything.
Boffin Emeritus
Re: Small Block vs Big Block [Re: polyspheric] #2622478
02/17/19 10:14 AM
02/17/19 10:14 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
There would be a point of deminishing returns in regards making the highest hp per cube, I recall it being somewhere in the 3-400 cube range. I can't recall exactly.
Whilst a big bore is always better in terms of airflow, it's not the case when it comes to friction. There is a presentation on YouTube about it, one of the Cup guys presented it at a AETC or something similar. Very interesting
Alan Jones
Re: Small Block vs Big Block [Re: WHITEDART] #2622540
02/17/19 03:00 PM
02/17/19 03:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW I had a BB that made 2.64 per cube. Oh did I mention it was a 99/06 Hemi smile Compared to some of the comp stuff that's just for beginners. I know of more than a few right at 2.8/2.9 that are in the 350-360" range
Re: Small Block vs Big Block [Re: WHITEDART] #2622611
02/17/19 05:40 PM
02/17/19 05:40 PM
New York
polyspheric Offline
polyspheric  Offline
New York
a big bore is always better in terms of airflow...
... and carries with it new problems w/r/t combustion chamber shape, charge energy loss, swirl, quench, mixture direction bias, flame front propagation, etc.
Smaller cylinders with very high B:S ratios make the most power, but the parasitic loads are not scaled, so a 90" V12 isn't as much better as you may suppose.
Boffin Emeritus
Re: Small Block vs Big Block [Re: polyspheric] #2622721
02/17/19 10:38 PM
02/17/19 10:38 PM
I have wondered about the parasitic loss due to big bore with short stroke versus small bore with a long stroke confused
I've always though that RPM was RPM ,no matter what the bore and stroke was for the same C.I. motor confused shruggy work
I understand the N/A Pro Stock type motors use a large bore(4.625+) with a short stroke to meet the rules of 500 C.I. but how much of that is to get the bigger valves in the heads versus running a 4.350 bore with a long enough stroke to make 500 C.I.? confused
Re: Small Block vs Big Block [Re: WHITEDART] #2622756
02/18/19 12:10 AM
02/18/19 12:10 AM
New York
polyspheric Offline
polyspheric  Offline
New York
I'm sure there are frictional differences between those choices, I'm just not up on them, perhaps someone can help?
Boffin Emeritus
Re: Small Block vs Big Block [Re: polyspheric] #2622783
02/18/19 01:14 AM
02/18/19 01:14 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
For the friction aspect, the long stroke would be at a disadvantage due to the higher rod angularity in the case of the SB (side loading piston more)? Longer stroke would also have higher piston speed, also increasing it's friction. Wonder how close to a wash it would be (BB vs SB friction)?
Re: Small Block vs Big Block [Re: Al_Alguire] #2622797
02/18/19 01:38 AM
02/18/19 01:38 AM
bean town ....Ca
W
W
bean town ....Ca
. I have a goal of 2.55 per cubic inch on the next W8 motor.. obviously dynos very. But 2.55 on the tool that we use is going to be tough
Re: Small Block vs Big Block [Re: WHITEDART] #2622822
02/18/19 04:23 AM
02/18/19 04:23 AM
LA360 Offline
LA360  Offline
For anyone that may have been interested, the section about efficiency starts at around the 10 minute mark.
https://www.youtube.com/watch?v=rBZCnG1HwDM
Alan Jones
Re: Small Block vs Big Block [Re: WHITEDART] #2622876
02/18/19 12:34 PM
02/18/19 12:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
But... that's rod ratio-dependent? Don't all BBC have short rods (stock 454: 1.53:1)?
Reduced by the smaller wall contact area?
Boffin Emeritus
Re: Small Block vs Big Block [Re: WHITEDART] #2622900
02/18/19 01:37 PM
02/18/19 01:37 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
BBC 454 is 1.53 ,BBC 427 and 396 were 1.636 SBC 400 1.466.
Re: Small Block vs Big Block [Re: ric3xrt] #2622952
02/18/19 04:03 PM
02/18/19 04:03 PM
I thought all three early BB Chevy type motors ran the same length rods confused
Wasn't the 396 motor the smallest bore with the same stroke as the 427 and the 454 increased the stroke from 3 3/4 to 4.0 inch stroke with the same 4.250 bore as the 427 had ? confused
Re: Small Block vs Big Block [Re: WHITEDART] #2622996
02/18/19 05:50 PM
02/18/19 05:50 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Same rod, inherited from the 348 W engine in 1958.
3.76" & 4.00"
Boffin Emeritus
