72-93 truck 3 point seat belt mounting #2622247
02/16/19 06:49 PM
02/16/19 06:49 PM
Walnut Creek, CA
blown340 Offline OP
blown340  Offline OP
Walnut Creek, CA
Hi all, I'm adding 3 point belts to my 73 W200. It already had the upper mount with a plug in it so the top is easy. On the bottom do the inertia reel and the second part of the bolt go in the same hole, or should be there two holes?
Better yet, does anyone have any pics of how the factory lower mounts are set up? wrench
Thanks,
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: 72-93 truck 3 point seat belt mounting [Re: blown340] #2622274
02/16/19 07:48 PM
02/16/19 07:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
What's a seat belt?
I have mechanical Aptitude.
I can screw up anything.
Re: 72-93 truck 3 point seat belt mounting [Re: blown340] #2622351
02/16/19 11:03 PM
02/16/19 11:03 PM
Guitar Jones Offline
Mine just have one bolt at the bottom.
Re: 72-93 truck 3 point seat belt mounting [Re: blown340] #2622404
02/17/19 01:18 AM
02/17/19 01:18 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A lot of the 3 point seat belts have an anchor point for the retract mechanism mounted at the floor or near the rocker panel. Then the belt goes up to the upper mount and a second lower bracket is often attached to either the rear of the seat track or the seat base, or has another mounting hole in the floor near the rear of the seat base. The buckle end will often share its mounting hole with one end or the other end of the center lap belt, depending on which 3 point belt your looking at.
The few I have seen that mount both the seat retracter and the the other lower belt attachment with the same bolt have different seat belt mounting ends so there is a spacing between the two parts of the belts.
When I install 3 point belts in something that did not originally have 3 point (or any) belts, I always use separate mounting points for the lower mounting points. I figure it spreads the load out more, and makes it easier to grab the belt to use it. I have mounted a lot of seat belts where there were not any. Gene
