72-93 truck 3 point seat belt mounting
#2622247
02/16/19 06:49 PM
02/16/19 06:49 PM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
Hi all, I'm adding 3 point belts to my 73 W200. It already had the upper mount with a plug in it so the top is easy. On the bottom do the inertia reel and the second part of the bolt go in the same hole, or should be there two holes? Better yet, does anyone have any pics of how the factory lower mounts are set up? Thanks, -Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
Re: 72-93 truck 3 point seat belt mounting
[Re: blown340]
#2622351
02/16/19 11:03 PM
02/16/19 11:03 PM
Posts: 20,665 in a cattle trailer down by th...
Guitar Jones
Mine just have one bolt at the bottom.
