Re: School me on center counter weighted cranks
[Re: Dragula]
#2621450
02/14/19 10:24 PM
02/14/19 10:24 PM
Posts: 10,002 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Ford stock 2011/19 5.0 cw cranks are sold as thier performance crank. Never had a failure! I run one from Crower in my 528. No cap walk anymore. They take the extra loads off 2& #4 bearings caus e d by non cw cranks, and put it on #3 where it belongs. Would reduce flexing of the crank also, adding to crank life.
[Re: Dragula]
#2621482
02/15/19 12:19 AM
02/15/19 12:19 AM
Posts: 4,206 New York
polyspheric
New York
The theory is sound, but the practical aspect? IIRC CCW cranks were used in 392 fuel engines back when, no improvement (Gene Adams). Perhaps this crank is inherently stiffer than current big blocks due to shorter OAL?
Boffin Emeritus
[Re: dthemi]
#2621526
02/15/19 02:25 AM
02/15/19 02:25 AM
gregsdart
The practical reasons for a ccw crank are better stock block life, and ultimate life of the crank. Also helping reduce or eliminate cap walk in my Megablock. Most racers won't really need one. But the advantages are there or Ford wouldn't use them in all 11 to 19 year 5.0 Mustang motors. Also as i said earlier , they sell that stock crank as thier performance part, zero failures. Some of those race turbo motors i assume are putting out some serious hp!
[Re: 340Cuda]
#2621687
02/15/19 02:48 PM
02/15/19 02:48 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
I'm putting another pump gas 400 stock 4.250 stroke block stroker motor that has a Windberg crank with billet steel Crower rods I bought used from a member back east several years back, it doesn't have the center counter weights I do have two fully counterweighted older top fuel or blown alcohol cranks, one is a Bryant that was 4.25 stroke with Mopar rod size(now offset ground down to BB Chevy size with 4.375 stroke) and the other is a older KB 4.500 stroke that was cracked in four places that I had fix with Mopar rod size, it couldn't be offset stroked though I'm planning on using both of those cranks in after market blocks to help prevent cap walk and see if I can exceed 1000 HP + N/A
[Re: Dragula]
#2621842
02/15/19 09:06 PM
02/15/19 09:06 PM
polyspheric
New York
Strictly speaking, for greatest control of out-of-balance forces, the counterweights should be moved inboard touching the cheek radius, and made as thin as possible to concentrate inertia as close directly opposite (180°, at the smallest diagonal) to the pins as possible, with the OD increased as needed to get the correct mass back. Any late weight adjustments (holes, Mallory) should be limited to the shallowest correction to the inner face of the CW only. Not practical. This is true (and nearly impossible) even for the "inherently perfectly balanced" L6 engines as well.
Note that the Winbergs shown are directionally biased for rotation...
Boffin Emeritus
[Re: polyspheric]
#2622089
02/16/19 12:50 PM
02/16/19 12:50 PM
Posts: 287 PA
Harry's Taxi 2
PA
Note that the Winbergs shown are directionally biased for rotation... So, is a center counterweighted crank an improvement or not?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Dragula]
#2622271
02/16/19 07:38 PM
02/16/19 07:38 PM
polyspheric
New York
Yes, but it's: 1. expensive 2. not magic - your power level and specific engine design may make it a conversation piece
You would also be faster if you center-drilled every fastener, like they did with Moto-X in the 1970s. 10 hours of labor to save 1 lb.
Expanding on my prior post: given a clean sheet of paper, a "V" engine can, and has been built with separate crank-pins at the same position (G.M.C. 301 etc. V6), which would allow a counterweight between them. But if you don't need it, it's just one more thing for the engineers to argue with the accountants...
Boffin Emeritus
[Re: Dragula]
#2622359
02/16/19 11:17 PM
02/16/19 11:17 PM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
Higher rpm engines seem to like CCW cranks. The weight becomes rotating inertia...not a bad thing.
Brian Hafliger
[Re: Dragula]
#2622367
02/16/19 11:28 PM
02/16/19 11:28 PM
polyspheric
New York
Ideally, every mass would be opposed by a counterweight placed exactly opposite: 180° away. This is not possible since the pistons occupy that space. Any compensating mass NOT correctly placed (alongside, diagonal, etc.) has the effect of forming a bending plane with its axis a line through both centers of mass - a diagonal angled away from the crank's axis of rotation. The greater the misalignment, higher RPM, and greater mass the stronger the bending force. Bad.
Boffin Emeritus
[Re: polyspheric]
#2622477
02/17/19 10:10 AM
02/17/19 10:10 AM
Posts: 287 PA
Harry's Taxi 2
PA
Ideally, every mass would be opposed by a counterweight placed exactly opposite: 180° away. This is not possible since the pistons occupy that space. Any compensating mass NOT correctly placed (alongside, diagonal, etc.) has the effect of forming a bending plane with its axis a line through both centers of mass - a diagonal angled away from the crank's axis of rotation. The greater the misalignment, higher RPM, and greater mass the stronger the bending force. Bad. So, does that mean CCW cranks do or don't reduce cap walk?
