Re: 1971 Cuda Exhaust Manifold / Header question for Hemi
[Re: fritzo34]
#2620739
02/13/19 12:49 PM
02/13/19 12:49 PM
Posts: 5,123 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Whos make of headers that are on the Cuda and what modifications are done to the Hemi.I ask this because maybe the headers are a better choice. I run hookers on mine the ones that a few pieces per side. No problems with Headers being to low. I run a Deeper oil pan and it is much lower than the headers. If you run a stock pan put some extra oil in it because if you make a pass likely your oil pump will fill the top of the hemi with oil and very little will be in the pan. Mario out of Detroit has the best prices on factory Manifolds. They are repops but fit OK. Price will be under 1000 dollars.
1971 HEMI E BODY REGISTRY
[Re: Cab_Burge]
#2621189
02/14/19 11:31 AM
02/14/19 11:31 AM
Posts: 4,467 Morristown Tn.
71birdJ68
Morristown Tn.
My headers are ceramic coated and still make the car hot. A race car and a street car are two different things. I guess it depends on what the car is used for.
[Re: ScottSmith_Harms]
#2621240
02/14/19 01:13 PM
02/14/19 01:13 PM
Posts: 1,379 Houston,Tx.
Lee446
Houston,Tx.
I have to say, the TTI headers that I put on my Hemi were the only ones of the many sets of headers, through the years, that I have put on, that required absolutely no modifications, no dings or even scratches. Twice a year, I check all bolts, zero issues in 7 years. I never really noticed any particular heat issues either, but, living in Texas made A/C mandatory, and I used one of the foil backed butyl rubber sound deadeners on the floorboards which did not hurt. Just my experience.
