1970 VS 1971 big block valve covers - early/late dates #2620159
02/12/19 05:53 AM
02/12/19 05:53 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
I believe there are at least 3 different RH (passenger side) valve covers that were used on big blocks for the 1970 & 1971 model years
A * narrow oil fill & no "divot"
B * narrow oil fill & "divot"
C * wide oil fill & "divot"
trying to determine when the changes took place
who has a late '70 or early '71 model year big block car (B, C, E-body & 383 or 440) with it's original valve covers: that can share their car's valve cover style, scheduled production date, engine assembly date and assembly plant info?
moparts 1970 VS 1971 RH valve cover big block 440 383.jpgmoparts rm23n1g108581-ft.jpgmoparts F383 5 1 R HP cast 4-16-70-ead.jpg
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: 6bblgt] #2620208
02/12/19 11:25 AM
02/12/19 11:25 AM
MarkMcDonald Offline
I will post a picture of the other side when I get a chance. This 71 383 HP SPD B18 has the raised round area on the front of the driver side valve cover. Early 71 383 & 440 HP engines have the flat cover like a 70. 2 different covers were used on the drivers side also!
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: MarkMcDonald] #2620234
02/12/19 01:00 PM
02/12/19 01:00 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
Dan,
I was thinking of talking with you about a post like this.
Thanks for posting.
This right side valve cover is from an untouched 70 Challenger 440-4bbl SPD B20 Nov 20th.
No indent in front
Did they add the indent because of the heater hoses?
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: VCODE] #2620298
02/12/19 04:00 PM
02/12/19 04:00 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
IMO the additional "BUMPS" & "divots" were to cut costs in the manufacturing process
the majority of 1970 covers "A" are what's needed - 2 different valve cover stampings
the first change "B" included the power brake booster "divot" on both sides
the second change "C" included 2 large "BUMPS" on each side
now the stamping was the same for both sides: piercings for holes & welding of shields/tabs/brackets made them side (and/or engine/body) specific
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: 6bblgt] #2620396
02/12/19 06:40 PM
02/12/19 06:40 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
Dan, now that makes sense. They use the same stamping for both sides saving time & money.
Thanks Bob
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: 6bblgt] #2620488
02/12/19 09:11 PM
02/12/19 09:11 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
What would be the actual timeline generally accepted for covers A-C???
Also when did the outer studs instead of bolts end? 1969? Part of 1970? I've never owned a 70 with them but other's have.
Ron
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: RJS] #2620625
02/13/19 01:44 AM
02/13/19 01:44 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
that's the whole point of the thread - I'll take a stab at it (looking for confirmation & contradiction) realcrazy
"A" - August 1969 thru May 1970 production
"B" - June 1970 thru November 1970 production
"C" - December 1970 thru July 1971 production
Also when did the other studs instead of bolts end? 1969? Part of 1970? I've never owned a 70 with them but other's have.
Ron
valve covers with 4-bolts & 2-studs were used until about the middle of 1971 production, let's call the introduction of 6-bolts at January 1971 alien
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: 6bblgt] #2620654
02/13/19 03:45 AM
02/13/19 03:45 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
here is a junkyard Imperial 440 3/30/71 - SPD
version "C" valve covers & 6-bolts scope
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: 6bblgt] #2620793
02/13/19 03:10 PM
02/13/19 03:10 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
My original (440+6) St. Louis 71 runner with a SPD of first week December 70 has style B. I haven't had a chance to look at the engine assembly date yet.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: Butterscotch71] #2622517
02/17/19 01:45 PM
02/17/19 01:45 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
440 valve covers 10/69 built LA Cuda. 9/25 engine assembly date stamped on top boss. this is a great detail discussion. keep in mind this is when I first got the car 11 years ago. the engine had a spray bomb job on the when I got it the car. I am also showing the driver side if anyone cares as well. sorry for the mess under the hood, I was in the disassemble/document phase at this point in 2008.
Super Commando
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: VCODE] #2622578
02/17/19 04:35 PM
02/17/19 04:35 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
Originally Posted By VCODE
Dan,
Thanks for posting.
This right side valve cover is from an untouched 70 Challenger 440-4 SPD B20 Nov 20th.
No indent in front
did not realize you could get a HP440 4speed w/AC. learn something new everyday
Super Commando
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: 70plymA34] #2622589
02/17/19 04:55 PM
02/17/19 04:55 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
Dan,
Thanks for posting.
No indent in front
Hi Mike, I just added bbl to my post. It should read 440-4bbl. The SPD means schedule production date B20 . Sorry for the confusion.
Bob
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: 6bblgt] #2622620
02/17/19 06:03 PM
02/17/19 06:03 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
no worries. in the end its all trivial nonsense. LOL
Super Commando
Re: 1970 VS 1971 big block valve covers - early/late dates [Re: 70plymA34] #2631678
03/12/19 03:45 AM
03/12/19 03:45 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
bump
anyone with a late '70 June/July big-block car that can share what their original valve covers looked like? shruggy
